Hey 70-72 Supreme owner's
Old Mar 24, 2016 | 05:18 PM
kbass72's Avatar
I bought a supreme that has '71 front fenders, grills, '71 bumpers front and back. The cowl tag and the vin say's it's a '70. It was originally green but was repainted black. The paint on the inside of the fenders look like the original green color so i'm not sure if these parts might have been put on after it had a repaint or? thoughts?
Old Mar 24, 2016 | 05:30 PM
Post a pic of the cowl tag and someone will be able to decode it and tell you how the car came from the factory.
Old Mar 24, 2016 | 05:33 PM
vette442's Avatar
I've had about a dozen 70-72 Supremes, but without more info or pictures, not sure if I can assist. What's the actual build date on the cowl tag? (lower left hand side, e.g. 11C) 1971 models were built for 4-5 months of 1970. What pattern is on the upper part of the seats? Four squares with buttons or the 2" vertical pleats? How about the trim woodrgain? Is it the knotty burlwood or more horizontal grain pattern?
Terry
Old Mar 24, 2016 | 05:53 PM
kbass72's Avatar
The car is at a friends house awaiting a drive train transplant so i can't take pics but it does have an O type 12 bolt if that helps. The front seats are long gone but still has the back.
Old Mar 24, 2016 | 09:06 PM
This is your key to unlock the cars history.
If the VIN and cowl tag says it's a 1970 model, then the entire front clip and rear bumper have been changed. The 1970 hood, grills, bumper, rad support will not allow 71 components to just bolt right up as mix and match. Only the fenders are compatible. So, you have a frankencar.
BTW, even though 1971 production started in July/August of 1970, The model years would never show VIN, nor the cowl tag information wrong. So your car has to be a 70 that someone has modified to suit their tastes. It might also have been in a front end wreck and parts replaced with what was available at the time?
Post some pictures of this car showing the front, rear, side and interior.
EDIT: Just saw the car has an O type rear. That's consistent with a 1970 model.
blunosr68
Apr 23, 2019 06:15 PM
lmetcalf
May 31, 2012 06:23 PM
ottospeed61
Dec 9, 2010 06:43 PM
satanic-mechanic
Feb 13, 2009 07:29 AM
evilla
Oct 11, 2008 04:10 PM
