center console
Old Mar 24, 2016 | 04:03 PM
prohandze's Avatar
center console
what year and model center consoles will fit the 64 f85 cutlass? And also what steering columns?
Old Mar 24, 2016 | 04:53 PM
lemoldsnut's Avatar
You did not say if it is an automatic or stick shift.
Column is 64-66 67 went to a colapsable column and had emergency flashers.
64-69 on a manual shift console (very hard and expense to come by these days)
64-66 on an automatic console. 67-69 you can probably make fit but is not correct. Point to be aware of 64-66 floor shift auto shifters have issues with the shifter shaft. Many will tell you it needs a new T handle. But, the problem is that the mounting tabs on the shifter shaft break off.
Hope this helps
Larry
ViceGuy
Dec 14, 2008 06:18 AM
Pastor Dave
May 29, 2008 08:41 PM
bear71
Mar 27, 2007 08:59 PM
ViceGuy
Feb 19, 2007 07:07 AM
ViceGuy
Oct 26, 2006 02:21 PM
