Wrong motor mounts?
Old Jun 24, 2023 | 12:05 PM
jimkep's Avatar
Wrong motor mounts?
Hello Joe,
I have a 66 Oldsmobile Cutlass 4 door and had a mechanic replace motor and trans mounts and the 330 small block raises and the fan hits the shroud with the slightest torque...it happens when I'm turning either direction from a stop with not much acceleration at all. Could the mechanic put the wrong mounts in??? Thank you for your help.
Old Jun 24, 2023 | 12:07 PM
I would pretty much guarantee it.
Old Jun 24, 2023 | 12:12 PM
I moved your post. This way you should get more folks to see it vs. resurrecting a 15 year old thread.
Did the fan move and hit the shroud before you took the car to the mechanic?
Old Jun 26, 2023 | 07:09 AM
jimkep's Avatar
Thank you Joe for your help. Have a great week and enjoy your July 4th celebration with your family.
Old Jun 26, 2023 | 07:11 AM
jimkep's Avatar
Thank you. I'm new and not sure how to navigate. Have a great day.
Old Jun 28, 2023 | 04:26 PM
jimkep's Avatar
Hello Joe,
I mentioned the other day about mechanic probably putting wrong motor mounts in 1966 Oldsmobile Cutlass Supreme because 330 small block moves under small amount of engine torque the fan blades hit the shroud with ease and have marred shroud. Can you please tell me what the proper engine mount is for this small block 330. I'm pretty sure i need engine mount #2261.
Thank you for your help and have a safe 4th of July with your family.
Jim
Old Jun 28, 2023 | 04:37 PM
66SportCoupe's Avatar
2261 IS the correct engine mount for your car
Old Jun 28, 2023 | 06:28 PM
Hello Joe,
Jim
Assuming your car has the original frame pads, 2261 is the correct mount for ANY Olds engine in your car.
Old Jun 28, 2023 | 08:01 PM
jimkep's Avatar
Thank you 66SportCoup and Joe Padavano.
Old Jun 29, 2023 | 04:03 AM
I know you already received the correct advice. If interested in reading a treatise on motor mount applications >>> Motor mount application list
JCMC64
May 26, 2017 10:04 AM
dream66
Apr 30, 2017 04:31 PM
billykissell
Jun 15, 2011 03:08 PM
Chumley
Feb 9, 2009 02:11 PM
Chumley
Jan 23, 2009 08:02 PM
