Painting my frame
Old Mar 10, 2007 | 07:50 AM
Ranzan's Avatar
Getting There
Painting my frame
hey guys well finally getting something done ..... gonna be taking my frame in for blasting along with trans mount rear end control arms.... now I am not a paint guy never done any gun work other than rattle can. I bought a set of spray guns.... primer/paint. I have lots of compressors due to construction trade can I use these with the spray guns or do I need something that will trap the condensation from the tank? I guess most paints you mix with an activator?
Old Mar 10, 2007 | 07:59 AM
mp71conv's Avatar
Painting
As long as you have an aircompressor big enough to supply the air you should be ok. They sell in line water filters. What type of paint are you going to use, Enamel or Laqure. Enamel will not be harmed with a little bit of moisture. Finally when buy the paint they should tell you what to mix and the ratio.
Old Mar 11, 2007 | 03:46 PM
American Lead's Avatar
2Blue 55
I would love to see some pics of your project. The important thing about the compresser is that it must be big enough to hold enough air for the air brush. Good luck with your project.
Old Mar 11, 2007 | 05:25 PM
Ranzan's Avatar
Getting There
heres some pics of the cars I have Robert old will be updating them once the frame is done hopefully by then I can get going on the body
https://classicoldsmobile.com/forums....html#post9965
Old Mar 27, 2007 | 08:40 PM
ijasond's Avatar
Purveyor of Polyurethane
Powder coat it.
The guy I use for sandblasting can go ahead and powder coat the frame for a very reasonable price(because it's already hanging there ready to go) so if it's not too late, check around, I bet you'll find someone to powder coat it for little more than just blasting(unless you're doing it yourself, in which case you'll find it very difficult to get your frame into your wife's oven). you'll end up with a much more durable finish, definitely the only way to go on a frame. If you decide that you are going to DIY, grab some chassis black & use the product the way it says to. You can find all the product data sheets for just about any product online. These will give you dry times, suitable primers, gun pressures, dry film thickness requirements, etc. It's amazing how much better the job can be when you follow the instructions. Good luck!
example: http://www.sherwin-automotive.com/me...glish/6131.pdf
johnsw-31
Jul 4, 2013 09:22 AM
Harmon
Feb 5, 2011 07:10 PM
Wilson05
Jan 26, 2010 01:23 PM
DJMatthews
Dec 5, 2006 01:28 PM
