455 fuel pump recommendations
Hey guys,
I'm looking for some recommendations for a fuel pump from my 455. It's probably in the 450+ hp range. I can't find any from Edelbrook or Holley that fit, but I've seen a Carter muscle car series pump that puts out 120 gph with 5.5-6.5 psi. Is this adequate for my motor? Looking for ideas.
Thanks,
Dave
Thanks,
Dave
the Carter fuel pump. another option is the RobbMc, like this one in the for sale forum https://classicoldsmobile.com/forums...fuel-pump.html
This pump will not fit if you use Edelbrock or Pro-Comp heads
I'll probably go with the carter.
Do I need a pump with a return if my car has a return line or can I just leave it disconnected?
In reference to the Carter pump- I am running the Carter pump on my 455 with Edelbrock heads. I did have to do a little filing in order for it to fit. No major cutting or water jacket problems. Also, no lack of fuel.
Ziff, I've also heard that Edelbrock heads get in the way of the fuel pump.
BTW Dave, I think that fuel pump you have a link to will work perfectly for you. Please note that if you have braided stainless steel fuel lines from the fuel pump to the carburetor you will need to get a 5/8" male inverted flare / AN adapter to put the braided stainless steel hose on the fuel pump. This adapter is hard to come by at auto parts stores. When I installed the braided stainless steel fuel line on my 71 98 I had to search hi and lo for the adapter. I finally found it at a specialty hydraulics store. I paid $10 for it (fortunately they are only about $2 on Summit).
http://www.summitracing.com/parts/sum-240115/overview/
Dave, I'm not sure if that will work or not. I'm certain that the Carter fuel pump needs a male fitting with inverted flare (since the stock fuel line went from the pump to the carburetor). I believe the NPT threads don't have an inverted flare.
On my 455 in the 57 Olds I filed the Edelbrock head to fit the fuel pump. On the one for the 48 Olds I dimpled the fuel pump just a tad. Both ways work but it the future I will always dimple the fuel pump
Do you have a part number for the fitting from Summit that worked?
Dave, the second part is the one you want! I bought the same part from a local hydraulics store and I had to pay over $10 for it. At least the guy had what I needed though, I was itching to get the car running that day.
Bluemeanie
March 5th, 2014 05:40 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
