455 fuel pump recommendations
Old October 2nd, 2013, 05:34 AM
"Trying to fix her right"
dfire25's Avatar
Hey guys,
I'm looking for some recommendations for a fuel pump from my 455. It's probably in the 450+ hp range. I can't find any from Edelbrook or Holley that fit, but I've seen a Carter muscle car series pump that puts out 120 gph with 5.5-6.5 psi. Is this adequate for my motor? Looking for ideas.
Thanks,
Dave
dfire25 is offline
Old October 2nd, 2013, 05:41 AM
Dave, I put that Carter fuel pump on my 455. It works great. If you want a "hi-performance" mechanical fuel pump this is the only option that I know of.
Olds64 is offline
Old October 2nd, 2013, 06:02 AM
dfire25's Avatar
Thanks olds64.
Do I have to have a return line fitting on the pump? My car has the 3 line system, supply, return, and emmisions.
dfire25 is offline
Old October 2nd, 2013, 06:10 AM
Look into the Airtex 40736, about 30 bucks from Advance Auto. A friend of mine had one on his 66 Olds. It ran 12.30s with that pump.
matt69olds is offline
Old October 2nd, 2013, 02:31 PM
junior supercar's Avatar
the Carter fuel pump. another option is the RobbMc, like this one in the for sale forum https://classicoldsmobile.com/forums...fuel-pump.html
junior supercar is offline
Old October 2nd, 2013, 04:51 PM
citcapp's Avatar
This pump will not fit if you use Edelbrock or Pro-Comp heads
citcapp is offline
Old October 2nd, 2013, 08:07 PM
dfire25's Avatar
Wow! Too rich for my blood.
I'll probably go with the carter.
Do I need a pump with a return if my car has a return line or can I just leave it disconnected?
dfire25 is offline
Old October 4th, 2013, 02:39 AM
If your car already has a return line I would get the pump with the return line. That is what I did on my 71 98.
Olds64 is offline
Old October 4th, 2013, 04:59 AM
dfire25's Avatar
This is probably what I'll get.
http://www.summitracing.com/parts/crt-m6109
dfire25 is offline
Old October 4th, 2013, 05:23 PM
ziff396's Avatar
In reference to the Carter pump- I am running the Carter pump on my 455 with Edelbrock heads. I did have to do a little filing in order for it to fit. No major cutting or water jacket problems. Also, no lack of fuel.
ziff396 is offline
Old October 4th, 2013, 10:35 PM
Ziff, I've also heard that Edelbrock heads get in the way of the fuel pump.
BTW Dave, I think that fuel pump you have a link to will work perfectly for you. Please note that if you have braided stainless steel fuel lines from the fuel pump to the carburetor you will need to get a 5/8" male inverted flare / AN adapter to put the braided stainless steel hose on the fuel pump. This adapter is hard to come by at auto parts stores. When I installed the braided stainless steel fuel line on my 71 98 I had to search hi and lo for the adapter. I finally found it at a specialty hydraulics store. I paid $10 for it (fortunately they are only about $2 on Summit).
Olds64 is offline
Old October 5th, 2013, 03:48 AM
dfire25's Avatar
Thanks olds64, that's exactly what I'm doing. Will this work?
http://www.summitracing.com/parts/sum-240115/overview/
dfire25 is offline
Old October 5th, 2013, 07:27 AM
Dave, I'm not sure if that will work or not. I'm certain that the Carter fuel pump needs a male fitting with inverted flare (since the stock fuel line went from the pump to the carburetor). I believe the NPT threads don't have an inverted flare.
Olds64 is offline
Old October 5th, 2013, 09:18 AM
citcapp's Avatar
On my 455 in the 57 Olds I filed the Edelbrock head to fit the fuel pump. On the one for the 48 Olds I dimpled the fuel pump just a tad. Both ways work but it the future I will always dimple the fuel pump
citcapp is offline
Old October 5th, 2013, 02:24 PM
dfire25's Avatar
Do you have a part number for the fitting from Summit that worked?
dfire25 is offline
Old October 5th, 2013, 08:43 PM
dfire25's Avatar
Did some searching. How about this?
http://www.summitracing.com/parts/sum-220667/overview/
dfire25 is offline
Old October 5th, 2013, 10:15 PM
Dave, the second part is the one you want! I bought the same part from a local hydraulics store and I had to pay over $10 for it. At least the guy had what I needed though, I was itching to get the car running that day.
Olds64 is offline
Old October 6th, 2013, 07:36 AM
Run to Rund's Avatar
The Holley red electric pump with no mechanical pump will work.
Run to Rund is offline
Bluemeanie
March 5th, 2014 05:40 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
sshriber
March 22nd, 2010 06:16 PM
oldscharm
November 11th, 2009 07:42 AM
Quick Reply: 455 fuel pump recommendations
