strange fuel concern 67 442
Old March 9th, 2012, 11:12 AM
this is not my car lol
scubastever's Avatar
this is an edelbrock (1405 ?) on my 67 442 with a strange concern of the fuel line draining back, upon engine shut off.
i installed a glass filter to video the draining back. eventually the fuel line is completely void of fuel, but fills up as the engine is cranked.
symptoms are:
sitting after 10 minutes, engine needs to be cranked over extensivley to fire up, but starts fine if only left to site a few minutes.
check out the video, let me know your thoughts!
is it a fuel pump issue? (as far as i know, there are no check valves preventing drain back..)
is it a carb issue (float seat no sealing)
thoughts?
http://www.youtube.com/watch?v=9Q2YbLAdcoY
scubastever is offline
Old March 9th, 2012, 11:27 AM
Rickman48's Avatar
Loosen the carb and slide a piece of thin cardboard in there, and check for a carb internal leak.
I can't think of any other way you could 'siphon' the fuel bowls, as the needle and seat are above the floats.
Once the fuel is below the float level, it must be letting air in, via needle, siphoning the line!
Rickman48 is offline
Old March 9th, 2012, 11:33 AM
Registered
Bluevista's Avatar
Non-vented gas cap?
Bluevista is offline
Old March 9th, 2012, 02:00 PM
Check you oil and see if it smells like gas! It maybe a faulty fuel pump.
oldcutlass is online now
Old March 10th, 2012, 12:17 PM
Thx for the ideas!
Old March 10th, 2012, 12:36 PM
Aloha, Tony
68442CONVERTCO's Avatar
Clogged return line?
Maybe take some air and blow the tank lines out.
Blue vista has a good point, try running the car with the gas cap removed.
Please remember to install it before moving the vehicle.
68442CONVERTCO is offline
Old March 10th, 2012, 02:02 PM
The fuel pump should have two check valves inside it - one in and one out.
If the "out" valve is leaky, it might let the line drain, but it shouldn't empty the float bowl, as mentioned above.
MDchanic is offline
Old March 10th, 2012, 08:16 PM
Texas Jim
Texas Jim's Avatar
That very same thing started happening to my 'Vette after changing from the Q-jet to an Edelbrock carb. I later on installed an Air Gap intake and after bolting everything back up, it stopped. I thought it was due to my getting rid of the vacuum canister and letting the system openly vent there, but I really don't know. I'm sure it's something very simple that we're over-looking/making it more complex than it is.
Texas Jim is offline
Tony85cutlass
May 18th, 2015 06:54 PM
Chumpy2112
April 30th, 2015 09:14 AM
costpenn
January 3rd, 2012 12:07 PM
EightballZ
June 28th, 2011 11:49 PM
TedH
January 23rd, 2009 07:42 AM
Quick Reply: strange fuel concern 67 442
