New Oil Pan Installation Concern
Old October 15th, 2011, 04:48 PM
costpenn's Avatar
Bought one of the Thorton reproductions for a 72 455 A body (beautiful looking piece). Am replacing the oil pump while I'm at it with the Melling high volume model with the bolt on pick-up screen. When I go to test fit the pan, it doesnt seem to want to go all the way and have the pan flange rest on the block unless I firmly press down on it. I'm worried that there might be some interference going on between the pick up and the pan - anyone else had this problem or this the way it normally should feel/install?
costpenn is offline
Old October 15th, 2011, 05:12 PM
DJS70cutlass's Avatar
It should sit down flush with little or no pressure, somethings hitting it for sure.
DJS70cutlass is offline
Old October 15th, 2011, 11:43 PM
64Rocket's Avatar
Measure the height of the oil pick up from the pan rail. Then measure the depth of the oil pan to the rails of the pan. That should tell you what is going on.
Gene
64Rocket is offline
Old October 18th, 2011, 05:28 AM
507OLDS's Avatar
It sounds like maybe you have a pickup for an aftermarket pan,which is longer,for a deeper pan.Take your original pump/pickup,and compare it with the new pieces.
507OLDS is offline
Old October 18th, 2011, 08:09 AM
Run to Rund's Avatar
If the engine is stock and you are using the stock reproduction 4 qt. pan (5 qt. total in the system), the high volume pump may not be a good idea. I'd use the standard volume pump with that small a pan.
Run to Rund is offline
Old January 3rd, 2012, 12:07 PM
costpenn's Avatar
Finally got around to installing the oil pan that I was having trouble with. It wasnt interfering with anything on the motor - I still had trouble test fitting it even without the oil pump being installed. It just needed to be gradually torqued down compressing the end gaskets (which seem to me excessively thick). The Thorton pan is made of heavy gauge steel and the rails remained dead straight as I was torqing it down.
costpenn is offline
Tony85cutlass
May 18th, 2015 06:54 PM
Chumpy2112
April 30th, 2015 09:14 AM
scubastever
March 10th, 2012 08:16 PM
TedH
January 23rd, 2009 07:42 AM
Quick Reply: New Oil Pan Installation Concern
