What Roller Rockers Will fit Under Stock Valve Covers?
Old November 7th, 2011, 12:57 PM
Aloha, Tony
68442CONVERTCO's Avatar
Hi everyone,
I am building a sleeper 455, and want to use stock valve covers on my C heads.
What brand of roller rockers will fit under the stock valve covers?
Thanks in advance,
Tony K.
68442CONVERTCO is offline
Old November 7th, 2011, 01:30 PM
cutlassefi's Avatar
For anything under .550 lift or so normally the problem isn't the rocker, it's the poly lock. Try using the shorter ones from Comp.
cutlassefi is online now
Old November 7th, 2011, 01:39 PM
same but different
don71's Avatar
Many have glued two gaskets together to gain a little clearance.
I've seen holes drilled in the baffle to accomodate the poly locks at full lift.
And..Ive seen the baffle removed completly for the same reason, but thats not the best plan.
don71 is offline
Old November 7th, 2011, 04:35 PM
ziff396's Avatar
You also can get 3/8" aluminum spacers on ebay. I have them and they are not that noticable.
ziff396 is offline
Old November 7th, 2011, 04:39 PM
Chevy budget Olds powered
coppercutlass's Avatar
x2 with ziff396 or buy the stamped chrome stock style tall valve covers and paint them the color of the engine. Those are on ebay too i got them most dont know the diffrence
coppercutlass is offline
Old November 7th, 2011, 06:08 PM
Warhead's Avatar
http://www.rocketracingperformance.c...q8t552rmel00l4
Warhead is offline
Old November 7th, 2011, 07:55 PM
yeah thats too much to just go up 3/8. i think paid 28 dollars for stamped steel stock style valve covers that where 3/8 taller they where chrome but mine have actually held up no rust.
Old November 8th, 2011, 04:29 AM
stevengerard's Avatar
how about the extra thick cork valve cover gaskets, I have a few set of those - aren't those still made?
stevengerard is offline
Old November 8th, 2011, 05:25 AM
Lady72nRob71's Avatar
Just upgrade to these - for free!!
Lady72nRob71 is offline
Old November 8th, 2011, 05:37 AM
Aloha, Tony
Thanks for the info.
Ladynrob - Love the matching air cleaner!
Old November 8th, 2011, 06:44 AM
Run to Rund's Avatar
Of course, you could stay with stock rockers. If too much lift, grind the slots longer. If valve spring pressure is under 400 lb open, they hold up well.
Run to Rund is offline
Old November 8th, 2011, 01:38 PM
Aloha, Tony
Thanks.
I can't wait to get it back from the machine shop to start the assembly.
Old November 8th, 2011, 01:45 PM
I used only the finest from Tupperware!
Old November 8th, 2011, 01:58 PM
firefrost gold's Avatar
http://i989.photobucket.com/albums/a...e/DSC01769.jpg
there is harland sharp rollers under these valve covers
firefrost gold is offline
Old August 21st, 2021, 10:22 AM
Scott Hyde's Avatar
Did you have to take out the baffles?
Scott Hyde is offline
Boilerz25
April 27th, 2014 07:08 PM
drjr56
November 29th, 2012 11:40 AM
W31driver
September 20th, 2012 04:44 PM
skryla
December 2nd, 2011 01:12 PM
oldzy
May 30th, 2011 06:06 AM
Quick Reply: What Roller Rockers Will fit Under Stock Valve Covers?
