What Roller Rockers Will fit Under Stock Valve Covers?
Old Nov 7, 2011 | 12:57 PM
68442CONVERTCO's Avatar
Aloha, Tony
Hi everyone,
I am building a sleeper 455, and want to use stock valve covers on my C heads.
What brand of roller rockers will fit under the stock valve covers?
Thanks in advance,
Tony K.
Old Nov 7, 2011 | 01:30 PM
cutlassefi's Avatar
For anything under .550 lift or so normally the problem isn't the rocker, it's the poly lock. Try using the shorter ones from Comp.
Old Nov 7, 2011 | 01:39 PM
don71's Avatar
same but different
Many have glued two gaskets together to gain a little clearance.
I've seen holes drilled in the baffle to accomodate the poly locks at full lift.
And..Ive seen the baffle removed completly for the same reason, but thats not the best plan.
Old Nov 7, 2011 | 04:35 PM
ziff396's Avatar
You also can get 3/8" aluminum spacers on ebay. I have them and they are not that noticable.
Old Nov 7, 2011 | 04:39 PM
coppercutlass's Avatar
Chevy budget Olds powered
x2 with ziff396 or buy the stamped chrome stock style tall valve covers and paint them the color of the engine. Those are on ebay too i got them most dont know the diffrence
Old Nov 7, 2011 | 06:08 PM
Warhead's Avatar
http://www.rocketracingperformance.c...q8t552rmel00l4
Old Nov 7, 2011 | 07:55 PM
yeah thats too much to just go up 3/8. i think paid 28 dollars for stamped steel stock style valve covers that where 3/8 taller they where chrome but mine have actually held up no rust.
Old Nov 8, 2011 | 04:29 AM
stevengerard's Avatar
how about the extra thick cork valve cover gaskets, I have a few set of those - aren't those still made?
Old Nov 8, 2011 | 05:25 AM
Lady72nRob71's Avatar
Just upgrade to these - for free!!
Old Nov 8, 2011 | 05:37 AM
Aloha, Tony
Thanks for the info.
Ladynrob - Love the matching air cleaner!
Old Nov 8, 2011 | 06:44 AM
Run to Rund's Avatar
Of course, you could stay with stock rockers. If too much lift, grind the slots longer. If valve spring pressure is under 400 lb open, they hold up well.
Old Nov 8, 2011 | 01:38 PM
Aloha, Tony
Thanks.
I can't wait to get it back from the machine shop to start the assembly.
Old Nov 8, 2011 | 01:45 PM
I used only the finest from Tupperware!
Old Nov 8, 2011 | 01:58 PM
firefrost gold's Avatar
http://i989.photobucket.com/albums/a...e/DSC01769.jpg
there is harland sharp rollers under these valve covers
Old Aug 21, 2021 | 10:22 AM
Scott Hyde's Avatar
Did you have to take out the baffles?
Boilerz25
Apr 27, 2014 07:08 PM
drjr56
Nov 29, 2012 11:40 AM
W31driver
Sep 20, 2012 04:44 PM
skryla
Dec 2, 2011 01:12 PM
oldzy
May 30, 2011 06:06 AM
