Valve covers clearance with roller rockers
Old Nov 29, 2012 | 10:36 AM
drjr56's Avatar
Hello all......just wondering the difference in stopping if I go to manual breaks. The car is a 69 442,weights 3700lbs w/o me in it,and has power front disc breaks,but vacuum is at10",@750rpm's.Car has no power accessories except for the breaks.Will stopping become difficult.If I need to get the valve covers off it's might be a problem with the booster there.I have roller rockers.The car had A/C but that was removed a long time ago,now I just have to replace the heater core box with one for a non a/c car and I'll have clearance on the other side.
Old Nov 29, 2012 | 10:46 AM
RAMBOW's Avatar
Ben
the difference between manual vs power brakes is a big misnomer. It has ZERO to do with improving your stopping power- it only assists in how easy it is to fully activate the brakes.
A lot of people compare manual brakes to the brakes on a power brake car with the engine turned off- but its not the same.
with manual brakes (w/o a booster) the mc pushrod goes into the upper hole in the brake pedal- instead of the lower hole required for power booster cars- this changes the leverage geometry which makes it considerably easier to stop than a car with power brakes w/ the engine not running.
I have had manual brakes on my last few cars because i prefer the feel and I hated dealing with the extra junk in the engine bay.
I have manual disk/drum brakes in my 66 and it works great.
I run a 1 1/8 deep bore MC and a generic disk/drum proportioning valve.
I have a Solid pedal, not too hard (although my wife did complain about it the first time she drove it). I have no trouble pushing it hard enough to lock up the brakes at will.
-Ben
Old Nov 29, 2012 | 11:04 AM
jfb's Avatar
jfb
Hey i have a pretty big street cam also and just consider this,I would suggest a vacuum reserve can from any parts house and just install it right etc.
Old Nov 29, 2012 | 11:40 AM
drjr56's Avatar
Actually the car stops pretty good,I was more concerned about eliminating the booster and if there would be a problem stopping.I can't remember ever having a car with manual breaks.Eliminating the booster would make it much easier to get the valve cover off, if I need to.Sounds like manual disc/drum break will work fine.....And I did use a vacuum reserve,and it did work pretty good. Thanks fellows.
68442CONVERTCO
Aug 21, 2021 10:22 AM
Boilerz25
Apr 27, 2014 07:08 PM
W31driver
Sep 20, 2012 04:44 PM
skryla
Dec 2, 2011 01:12 PM
oldzy
May 30, 2011 06:06 AM
