composite distributor gear
Old January 29th, 2021, 08:09 PM
lukestmz's Avatar
I just seen that B O P has released a composite distributor gear for Oldsmobile, and would like some opinions on using them, I am not building a race car, I am using a roller cam, so what is the word on these good ? or am I better off with a melonized gear?
lukestmz is offline
Old January 30th, 2021, 07:45 AM
Mr Nick's Avatar
What type of metal the roller cam?
Mr Nick is offline
Old January 30th, 2021, 10:02 AM
lukestmz's Avatar
its a lunati voodoo , they say to use a brass gear on the web site
lukestmz is offline
Old January 30th, 2021, 11:41 AM
Gary
VC455's Avatar
Brass gear is old-school. It wears and needs monitoring, although nickel-aluminum-bronze (AMPCO alloy) has better durability.
Melonized (QPQ) is far better as you intimate, and composite could be even better--I'm interested to see how our more knowledgeable associates evaluate it.
VC455 is offline
Old January 30th, 2021, 01:12 PM
cutlassefi's Avatar
What distributor do you have?
cutlassefi is offline
Old January 31st, 2021, 04:03 PM
lukestmz's Avatar
I need a .491 shaft , only dick miller seem to have a melonized , unless someone knows of another supplier
lukestmz is offline
Old January 31st, 2021, 04:35 PM
cutlassefi's Avatar
Correct. Or, for all, you could’ve ordered an IG (iron gear) core from the start and negated the need for a special Dist gear.
Old January 31st, 2021, 05:56 PM
rickw30's Avatar
Howards cams had .491 melonized gears.
part # 94456
rickw30 is offline
Old February 1st, 2021, 06:59 AM
Duh
Duh's Avatar
Link please?
Duh is offline
Old February 1st, 2021, 07:37 AM
Gary
VC455's Avatar
Originally Posted by Duh
Link please?
I asked BOP about the gear and got this reply:
"Yes we have them in both .491 and .500. We have not yet had time to put them on the website. They are $169.99 each. Give us a call anytime"
VC455 is offline
Old February 1st, 2021, 03:36 PM
cutlassefi's Avatar
They cost less than $50.00 to make. Good for them if they can get it.
Old February 1st, 2021, 10:18 PM
lukestmz's Avatar
I got the cam for a very good deal, even with the gear I am a couple hundred ahead, just want to make the right choice, I am going to get the melonized gear
lukestmz is offline
Old February 2nd, 2021, 05:38 AM
cutlassefi's Avatar
i got the cam for a very good deal, even with the gear i am a couple hundred ahead, just want to make the right choice, i am going to get the melonized gear
Old February 2nd, 2021, 06:42 AM
oddball's Avatar
While we're on the topic, what are the part numbers / manufacturers for the 0.500" shaft (MSD) melonized gears? I find it surprisingly opaque to understand what the manufacturers are saying about their gears. MSD isn't even showing replacement gears on their website (?!?!?!)
oddball is offline
Old February 2nd, 2021, 11:55 AM
cutlassefi's Avatar
You have to call and get their replacement number. I have it somewhere, I’ll get it for you.
Old April 24th, 2021, 11:17 AM
72GrnCS's Avatar
I am also looking for a .500 gear to match a roller cam. So would the BOP engineering melonized , be the only choice at this time?
72GrnCS is offline
Old October 24th, 2022, 11:01 PM
lukestmz's Avatar
ended up with the composite gear, i could not get a melonized one, well so far so good, let everyone know after some miles on it
lukestmz is offline
Old October 25th, 2022, 08:36 AM
bccan's Avatar
Can you provide info? My kid is in need, wore the bronze gear to where the car shut off. We stabbed another HEI in there to keep him going but he’s trying to navigate the .491 gear thing right now.
bccan is offline
Old October 25th, 2022, 06:23 PM
Gary
VC455's Avatar
BOP has the composite gear in both bore diameters.
VC455 is offline
Old October 26th, 2022, 11:39 PM
lukestmz's Avatar
i got it from BOP , just go to the website, just get the one for the size of the distributor shaft
lukestmz is offline
Old October 27th, 2022, 05:05 AM
Gary
VC455's Avatar
Before you install that expensive distributor gear, examine the cam gear. If it's been damaged, you would need a new cam.
VC455 is offline
Old October 27th, 2022, 05:32 AM
bccan's Avatar
Valid advice, but this is a kid’s (at least back when he started) daily driver with well over 100k on the engine that I built 14 years ago, expecting him to drive the car maybe 5 years. That gear has tens of thousands of miles on it and granted, only remnants of teeth! Engine suffered a broken valve spring 2 years ago resulting in having the heads redone and now this distributor gear, the only two breakdowns. Very soon, the snow tires go on for car’s 13th winter since “restoring” it. Though the proactive approach is certainly valid, if/when the engine stops, we’ll check the cam, until then, it gets stitches on the bench and put back in the game!
bccan is offline
Old November 5th, 2022, 10:33 PM
pettrix's Avatar
The composite gear is now $180
Does anyone sell a Melonized .500 gear for the Holley distributor?
pettrix is offline
Old November 6th, 2022, 08:21 PM
Mr Nick's Avatar
MSD (owned by Holley) told me a few years ago that the gears that come with their distributors are melanized. I've been using a factory MSD gear with my roller cam for a good 15k miles, no issues.
Mr Nick is offline
Old November 6th, 2022, 09:10 PM
pettrix's Avatar
Interesting, I did not know that. I thought they were just steel gears. On the Summit website, it shows the gear material as "steel"
pettrix is offline
Old November 6th, 2022, 10:01 PM
OLDSter Ralph's Avatar
What did you think they were ?
OLDSter Ralph is offline
Old November 7th, 2022, 08:33 AM
Mr Nick's Avatar
Found the old email, wow it was 8 years ago!
Reply from MSD Tech "The MSD Oldsmobile distributor comes with a Melonized gear that makes it compatible with with GM billet roller cams. If your cam manufacturer recommends a composite gear, then use a composite gear."
He may be referring to factory GM roller cams, but like I said I've been running the normal MSD gear with my Erson roller cam for 8 years and 15k miles with no issues. I pulled the distributor out in the Spring and inspected the gears for a few years, and everything looked fine. I have not looked or worried about it for 5+ years now. Just my experience.
Mr Nick is offline
lukestmz
May 19th, 2020 08:40 AM
big man
April 1st, 2018 08:40 AM
1970Olds442
November 24th, 2017 07:15 AM
lyev
June 14th, 2015 04:08 PM
drjr56
September 9th, 2012 08:05 PM
Quick Reply: composite distributor gear
