Newbie needs some guidance on accy brackets
Old June 29th, 2018, 12:07 PM
Dfulton's Avatar
Hello. I’m an old newbie. I have no experience with Olds. The reason I joined is I
bought a 1955 Pontiac Safari and it has a 1965 Olds 442 engine with no power steering brackets and no alt.bracket (crappy homemade). My question is what will work on this? This is probably in the wrong place. Sorry
Dfulton is offline
Old June 29th, 2018, 02:26 PM
Welcome to the site, I moved your thread.
oldcutlass is online now
Old June 29th, 2018, 03:28 PM
Welcome. You didn't mention A/C so I'll assume that is not needed.
Which brackets you want depends on the available space. The 65-67 cars used high mount PS pump brackets. If clearance to the frame or steering box is an issue, you probably want to use these. This is a 1965. The 66-67 cars used an alternator bracket that looks like the later ones, but the alternator is in the same place.
The 1968-76 cars used brackets that mount the PS pump low on the driver's side. These are probably more common.
joe_padavano is offline
Old July 1st, 2018, 10:25 AM
Dfulton's Avatar
Brackets
Thanks. Sounds like what I need. Now just finding them
Dfulton is offline
Old July 1st, 2018, 11:37 AM
Do Damage
67CSConvert455's Avatar
I just went through the same bracket headaches, Joe and Nick were very helpful. Here’s the link.
https://classicoldsmobile.com/forums...ve-covers.html
67CSConvert455 is offline
exotec
May 17th, 2020 01:05 PM
brandon reynolds
January 12th, 2019 05:48 AM
allyolds68
March 7th, 2016 06:36 AM
hilbily
August 29th, 2014 09:39 PM
Eclipse_the_Wagon
November 16th, 2011 10:14 AM
Quick Reply: Newbie needs some guidance on accy brackets
