Newbie needs some guidance on accy brackets
Old Jun 29, 2018 | 12:07 PM
Dfulton's Avatar
Hello. I’m an old newbie. I have no experience with Olds. The reason I joined is I
bought a 1955 Pontiac Safari and it has a 1965 Olds 442 engine with no power steering brackets and no alt.bracket (crappy homemade). My question is what will work on this? This is probably in the wrong place. Sorry
Old Jun 29, 2018 | 02:26 PM
Welcome to the site, I moved your thread.
Old Jun 29, 2018 | 03:28 PM
Welcome. You didn't mention A/C so I'll assume that is not needed.
Which brackets you want depends on the available space. The 65-67 cars used high mount PS pump brackets. If clearance to the frame or steering box is an issue, you probably want to use these. This is a 1965. The 66-67 cars used an alternator bracket that looks like the later ones, but the alternator is in the same place.
The 1968-76 cars used brackets that mount the PS pump low on the driver's side. These are probably more common.
Old Jul 1, 2018 | 10:25 AM
Dfulton's Avatar
Brackets
Thanks. Sounds like what I need. Now just finding them
Old Jul 1, 2018 | 11:37 AM
67CSConvert455's Avatar
Do Damage
I just went through the same bracket headaches, Joe and Nick were very helpful. Here’s the link.
https://classicoldsmobile.com/forums...ve-covers.html
exotec
May 17, 2020 01:05 PM
brandon reynolds
Jan 12, 2019 05:48 AM
allyolds68
Mar 7, 2016 06:36 AM
hilbily
Aug 29, 2014 09:39 PM
Eclipse_the_Wagon
Nov 16, 2011 10:14 AM
