Intake Manifold question
'68 400 Turnpike Cruiser
Just over 100,000 miles - single owner car until we bought it.
Original owner has not had the intake manifold gasket replaced, ever.
The attached photos show apparent leak where intake meets the heads. It does not smell overtly like oil or antifreeze.
I have read several post on this forum regarding the tray style metal gasket and the sealing methods. Any recommendations on brand and sourcing of intake gasket?
Turnpike, looks like normal seepage for a '68 with 100k on the clock. Is it actually dripping out anywhere? I'd be more concerned about the original timing chain myself. Were Olds nylon geared back then? Scarey! Enjoy your ride, would like to see some pics. Good luck.
I agree with "shiftbygear". The original nylon timing gears are probably starting to crack and break off by now. If you want to clean up the engine, I would go a few hours deeper into replacing the timing set, water pump, intake gasket, and valve cover gaskets.
The pictures you show are normal road dust collecting minor seepage. Not usually a problem for driving the car.
I would do the chain as mentioned above as well as the fuel pump, when you have it all apart
yup my brother took our old 67 vc to chicago one summer to my sisters.he got back took all his stuff in the house and went to go downtown for something and it wouldn't start,timing chain jumped when he shut it off.it had about 110k on it.
That seepage could be engine oil from the valve cover gaskets and oil filler tube and cap. The intake gasket is probably fine. Fel pro makes the tray type gasket and other brands use it, with the Fel Pro logo stamped into it.
Appreciate the added suggestions on timing chain/gears.
I have read numerous threads now on the nylon timing gears. One even showed the pieces that were trapped in his oil pump pick-up screen. I have reached out to original owner to see if it has ever been changed.
I am ready to do that as well along with water pump.
shamusj
December 18th, 2014 09:28 AM
svnt442
July 17th, 2011 04:43 PM
