455 dual exhaust headers that are small for clearance?
Old May 31, 2016 | 01:33 PM
GHOSTOWLGRID's Avatar
455 exhaust manifold and corssover pipe matchup help?
Swapping a 455 in place of my 307 on my Cadillac Brougham, 1987.
(With trans and other)
I found on ebay there are factory 455 exhaust manifolds with the 3 bolt exhaust flange for single exhaust and can take a crossover pipe.
Do you know if I can buy those 455 manifolds and use the crossover from my olds 307's manifolds?
Old May 31, 2016 | 02:49 PM
The SBO crossover will be too short for the 455 application.
There is a current discussion about the differences here:
https://classicoldsmobile.com/forums...over-pipe.html
Old May 31, 2016 | 03:13 PM
Ok thanks. Would have been easier because I could have kept the single exhaust without much effort, but since I'd have to get a pipe made up, I might as well get a dual exhaust for not much more.
I have been looking at these for a dual exhaust, looks pretty good:
http://www.ebay.com/itm/Oldsmobile-C...hEn88w&vxp=mtr
Says 455 big block. I mostly just wanted to verify that it will for sure fit the 455 since I'm here.
Old Jun 1, 2016 | 06:59 AM
Those manifolds will fit your 455. I don't know if there would be enough clearance for your conversion though.
Old Jun 1, 2016 | 09:46 AM
Those W/Z manifolds should work fine in your D-body Caddy.
70-442-W30
Wheels and Tires
15
Feb 2, 2016 08:32 AM
Funkwagon455
May 14, 2015 06:44 PM
May 30, 2012 05:47 AM
67townsedan
Aug 25, 2011 10:15 AM
mutzi
Jul 15, 2009 10:45 PM
