powermaster 9610 won't fit 455?
Old May 11, 2023 | 02:51 PM
vmathy's Avatar
I ordered a powermaster 9610 starter, says it fits all olds v8. I went to install it and it is not even close, the gear is way too far in to the flex plate. Any one else had this issue or know what part is correct?
Old May 11, 2023 | 03:52 PM
Which way, is it the starter drive not reaching into the flexplate or it's too far above the gear for the teeth to contact?
Old May 11, 2023 | 04:01 PM
vmathy's Avatar
The gear on the starter is to far into the flex plate. The shaft is almost lined up with the teeth. for this starter to work its like the flex plate would need to be about a half inch smaller.
Old May 11, 2023 | 06:03 PM
Are you sure this isn't improperly boxed? It wouldn't be the first post where that happened.
Old May 11, 2023 | 06:14 PM
vmathy's Avatar
Joe, that's the first thing I thought. It is stamped 9610 on the machined part but I guess it could be stamped wrong too.
Old May 11, 2023 | 06:20 PM
Well, 9610s bolt to Olds motors, so if yours doesn't, it's obviously mis-marked or improperly machined. Post a photo or two.
Old May 12, 2023 | 06:49 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Even the sbc mini starters bolt right on, something isn't right. My 9610 bolted right on my 403.
DerekW
Aug 25, 2025 10:22 AM
Pug Wrangler
Apr 3, 2023 06:16 PM
Tjohn8573
Mar 29, 2020 07:34 PM
Sporty45
Nov 9, 2016 07:32 AM
Olds luvr
Sep 13, 2014 02:26 PM
