powermaster 9610 won't fit 455?
I ordered a powermaster 9610 starter, says it fits all olds v8. I went to install it and it is not even close, the gear is way too far in to the flex plate. Any one else had this issue or know what part is correct?
The gear on the starter is to far into the flex plate. The shaft is almost lined up with the teeth. for this starter to work its like the flex plate would need to be about a half inch smaller.
