oil priming problems
Old June 17th, 2015, 06:04 AM
jawsmon's Avatar
I've put a 1970 455 back together after some minor crank shaft work and new bearings. I hook up the drill to the oil pump shaft and spin it CCW for 3-4 minutes. Oil preassure comes up to 65 right away. I have oil coming out of about half the lifters. I pulled all of the pushrods and flushed them in the parts washer. Tried again with same results. I rotated the crank several times and tried again. Got oil out of a couple more but there are about 6 really stuborn ones. Any suggestions?
jawsmon is offline
Old June 17th, 2015, 06:31 AM
It takes a long while 15 minutes or more.
oldcutlass is offline
Old June 17th, 2015, 06:57 AM
jawsmon's Avatar
I'll try again and keep going until I get the desired results. Any suggestions on a drill support so I can turn it on and walk away.....hmmmm
jawsmon is offline
Old June 17th, 2015, 07:17 AM
I've never tried a support. Rotating the engine a 1/4 turn helps.
Old June 17th, 2015, 07:27 AM
jawsmon's Avatar
I've rotated it several times- 1/4 turn, 1/2 turn, 360+ without any noticible change.
jawsmon is offline
Old June 17th, 2015, 09:27 AM
Octania's Avatar
Start the engine and let it do its thing
Octania is offline
Old June 17th, 2015, 12:12 PM
Oldsragger's Avatar
When i primed my engine with a batterydrill, it tooks time that the oil come up, in the beginning it comes out only few places, then i begin to turn the crank little by little when priming between, to the end it comes out of all lifters. Took some time but it worked.
What oil u use?
Oldsragger is offline
Old June 17th, 2015, 01:51 PM
What size drill are you using?
Old June 17th, 2015, 02:31 PM
jawsmon's Avatar
I'm using a 1/2" drill motor- plug into the oulet type. I set it up to run hands free and turned it on for 20 minutes. There was minor improvement but not much.
I'm not a big fan of "start it up and let it do it's thing". I've had excelent success in the past using this priming method. This is the first time I've had this kind of difficulty.
jawsmon is offline
Old June 22nd, 2015, 09:03 PM
jawsmon's Avatar
I'm glad I continued to troubleshoot the issue. The root of the problem is crudded up lifters. The hydraulic plunger was froze in many of them. Replaced the cam, lifters and valve springs. The oil is pumping like crazy. I can now have confidence in this motor knowing that all is well.
jawsmon is offline
Old June 23rd, 2015, 07:25 AM
Glad you found your issue. We assume lifters in good shape.
fv64olds98
March 2nd, 2013 11:13 AM
84oldsDelta88
March 21st, 2011 06:21 PM
JRios
September 29th, 2010 08:39 PM
dallasite21
August 31st, 2010 07:54 AM
Wasted
November 22nd, 2008 05:59 PM
Quick Reply: oil priming problems
