oil priming problems
Old Jun 17, 2015 | 06:04 AM
jawsmon's Avatar
I've put a 1970 455 back together after some minor crank shaft work and new bearings. I hook up the drill to the oil pump shaft and spin it CCW for 3-4 minutes. Oil preassure comes up to 65 right away. I have oil coming out of about half the lifters. I pulled all of the pushrods and flushed them in the parts washer. Tried again with same results. I rotated the crank several times and tried again. Got oil out of a couple more but there are about 6 really stuborn ones. Any suggestions?
Old Jun 17, 2015 | 06:31 AM
It takes a long while 15 minutes or more.
Old Jun 17, 2015 | 06:57 AM
jawsmon's Avatar
I'll try again and keep going until I get the desired results. Any suggestions on a drill support so I can turn it on and walk away.....hmmmm
Old Jun 17, 2015 | 07:17 AM
I've never tried a support. Rotating the engine a 1/4 turn helps.
Old Jun 17, 2015 | 07:27 AM
jawsmon's Avatar
I've rotated it several times- 1/4 turn, 1/2 turn, 360+ without any noticible change.
Old Jun 17, 2015 | 09:27 AM
Octania's Avatar
Start the engine and let it do its thing
Old Jun 17, 2015 | 12:12 PM
Oldsragger's Avatar
When i primed my engine with a batterydrill, it tooks time that the oil come up, in the beginning it comes out only few places, then i begin to turn the crank little by little when priming between, to the end it comes out of all lifters. Took some time but it worked.
What oil u use?
Old Jun 17, 2015 | 01:51 PM
What size drill are you using?
Old Jun 17, 2015 | 02:31 PM
jawsmon's Avatar
I'm using a 1/2" drill motor- plug into the oulet type. I set it up to run hands free and turned it on for 20 minutes. There was minor improvement but not much.
I'm not a big fan of "start it up and let it do it's thing". I've had excelent success in the past using this priming method. This is the first time I've had this kind of difficulty.
Old Jun 22, 2015 | 09:03 PM
jawsmon's Avatar
I'm glad I continued to troubleshoot the issue. The root of the problem is crudded up lifters. The hydraulic plunger was froze in many of them. Replaced the cam, lifters and valve springs. The oil is pumping like crazy. I can now have confidence in this motor knowing that all is well.
Old Jun 23, 2015 | 07:25 AM
Glad you found your issue. We assume lifters in good shape.
fv64olds98
Mar 2, 2013 11:13 AM
84oldsDelta88
Mar 21, 2011 06:21 PM
JRios
Sep 29, 2010 08:39 PM
dallasite21
Aug 31, 2010 07:54 AM
Wasted
Nov 22, 2008 05:59 PM
