OIL filter adaptor to block
Thanks...I think i will go witht the metal one. On closer inspection you can almost see the shape of the old one.wonder why the kit has one of each
There are 2 different gasket patterns if I remember correctly.
One for rear wheel drive, and one for front wheel drive.
MATCH UP THE PATTERNS FIRST. Worry about the materials second.
Good luck.
Good luck.
Both will bolt up....the fiber one is a better fit. That is the one that I will choose. Asked the builder today and he also suggested the fiber gasket.
