OIL filter adaptor to block
Old Apr 2, 2012 | 04:02 PM
CLcutlass's Avatar
My gasket kit has 2 gaskets for the filter housing to block. A crush type metal one and a felt one. Which goes where or do just one of them get used.
Old Apr 2, 2012 | 04:04 PM
Oldsmaniac's Avatar
I have seen metal ones which are factory style and felt ones and combination metal and felt. I would use the metal one with some high tack spray on each side...
Old Apr 2, 2012 | 05:18 PM
CLcutlass's Avatar
Thanks...I think i will go witht the metal one. On closer inspection you can almost see the shape of the old one.wonder why the kit has one of each
Old Apr 3, 2012 | 05:05 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
There are 2 different gasket patterns if I remember correctly.
One for rear wheel drive, and one for front wheel drive.
MATCH UP THE PATTERNS FIRST. Worry about the materials second.
Good luck.
Old Apr 3, 2012 | 02:35 PM
CLcutlass's Avatar
Good luck.
Both will bolt up....the fiber one is a better fit. That is the one that I will choose. Asked the builder today and he also suggested the fiber gasket.
Old Jan 14, 2019 | 01:22 PM
spencer83's Avatar
Gasket...
Good luck.
do you have product # on the gasket. Rear wheel
Old Jan 14, 2019 | 02:29 PM
Rather than resurrecting a bunch of five, six, and seven year old threads, why don't you just start your own thread and ask the question?
JPMDaddy
Jan 14, 2019 08:41 PM
ostie13
Oct 2, 2016 08:49 AM
davidstereo
May 14, 2012 08:09 PM
1971
Oct 18, 2011 08:42 AM
defiant1
Aug 26, 2011 09:45 AM
