Hey Guys,
Redoing my engine compartment and tune up...
Can you give your $.02 on these plugs?
The engine has around 5K miles. It was built 15 years ago. I do "not" have the specs. It was built above stock performance. Got a mild cam.
These are R45S's. FYI- The threads are wet due to WD40.
I do have new (15 years old)set of R46S that came with it.
Would it be OK to run these?
thanks guys!
Yes it desperately needs some highway.
My buddy owned it for 16 years before I got it. He only did short drives and the 5K miles over the 16 years.
I will definitely be changing that!
I have what I think is a lifter ticking, or need to adjust the valves, in that area. Could this be the culprit?
the valves have not been adjusted since initial rebuild. I just yanked the valve covers and some of the push rods are a little loose. Is this normal?
Got a 455 built up a little. I do not have specs. 4K to 5K miles on the new build (15 years ago). My best friend owned (obviously didn't drive much) and now I have it. Yes, it will definitely see more miles!
Got a mild cam and just popped the valve covers to find rollers.
I have a ticking on the drivers side and was not sure what it was.
Can these be adjusted? Nothing has been done since the build.
Also, below is a pick of the plugs. The 3rd one is crusty. Maybe that is the culprit. Not sure.
I'm a novice and need some advice.
thanks!
rick
I generally agree with what's been said. The R46S would work, but should be monitored for pre-ignition and plug condition. What you have seems normal except for the one with the heavier deposit. You might consider doing a compression check and inspection of the valve stem seals. Running the plugs through a checker might reveal a shortfall in the one with the heavier deposit.
