Front galley plugs... Do they need thread sealer?
Old Dec 7, 2012 | 10:47 PM
RAMBOW's Avatar
Ben
like the title says... should the front oil galley plugs have thread sealer on them, or just be put in dry.
any particular torque spec on them or just in till tight?
Thanks!
Finnaly installed my Voodoo 60803 tonight, getting ready to degree it tomorrow, then button up the bottom end!
Old Dec 8, 2012 | 06:38 AM
The factory didn't use sealer, I have never used any, I don't think its needed. If I remember correctly the torque spec is 35 ft lbs.
Old Dec 8, 2012 | 07:46 AM
Run to Rund's Avatar
Just oil them and install. I'd use Permatex on the rear plugs as they are NPT.
Old Dec 8, 2012 | 08:39 AM
Octania's Avatar
Where is the front going to leak to, the crankcase?
As for the rear, the RH NPT unit should be sealed, as it would leak to the exterior. The LH is NPT but needs no sealant, again, it would leak to... the crankcase.
The LH rear -does- however need to have a HOLE IN IT. To lube the distributor gear &c.
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
RandyS
Dec 26, 2013 10:57 AM
Sampson
Dec 5, 2013 03:09 PM
OldsMotion
Jan 12, 2013 12:50 PM
auto_editor
Jul 10, 2011 11:20 AM
