Oil galley plugs/restrictors
Just a question... I am having a hard time locating .030 drill bits... well at this point Dremel bits that are worth a damn to drill holes in these generic oil galley plugs in the block... The dremel ones dull in 2 seconds and there isn't any place local that seems to carry them or have a clue that they exist..
Has anyone ever drilled them at 1/16" or .0625 with any good or bad results???
Or do I need to resort to the interwebs to locate/order some?
John
John
Shop around
A #69 drill is about 0.0292" and a #68 drill is about 0.031"
If you have a Harbor Freight Tools store nearby (or are willing to use their mail order), they have a mini drill set available (so you don't have to buy an entire set of number drills). It has five 0.8mm drills in it. They are about 0.031".
http://www.harborfreight.com/30-piece-hss-mini-drill-set-94606.html
This is a Chinese product, and may require some patience to be successful, but if you follow the "hardness" advice given, they may work.
Other possibilities might be a local machine shop that you are "friends" with, or an on-line purchase.
Last edited by Ozzie; January 11th, 2013 at 12:24 AM. Reason: grammar/spelling correction
Thanks guys, I've got some carbide bits on the way...but I'm still going to follow the heating advice above. I also had a "duh" moment and will canibalize them from another block that won't see action for a while. ;-)
Watch with my luck the distributor side one won't be drilled...
John
John
The hole in the distributor galley plug is .040". You can get the bits at a model/hobby store such as Hobby Town. Use a pin vise and chuck it in your drill press. Start the hole with a larger bit will make it easier. Go slow. Good luck.
I'm lazy- i just called mondello and the plug was here a couple days later.
My time running around town trying to find a drill bit- then hoping i don't break it drilling the hole (which i would have)... Not worth the price of the pre-drilled plug.
