Cam for street build 455
Old Apr 24, 2018 | 07:08 AM
76sbo's Avatar
I do not post much but this site has been a treasure for information. I have a 1973 cutlass S that I put a 455 from a 73 toro in last year. The motor has around 60,000 miles and runs good. I will be pulling it to do a few upgrades and fix some leaks.
It has a Edelbrock performer cam, Edelbrock intake, Edelbrock timing chain and gears, rebuilt quadrajet toro carburetor, MSD Distributor and coil, stock J heads. and stock air conditioning.
I have large valve stock C heads that i will put on. I have two questions:
I ordered cometic .027 head gaskets. Is this ok for the heads?
Is there a better cam choice for this motor while I have it out?
It also has 2.5" exhaust with glass packs and Thortons W/Z manifolds.
Just a street driver no track. I would like a little more muscle car tone and torque. I have searched this site with no real answers to my questions. I will be changing gear ratio from stock in the near future also.
Old Apr 24, 2018 | 07:52 AM
svnt442's Avatar
In my opinion the limiting factor on your cam choice will be the factory pistons. The compression is around 8:1 and if you go too big it will be a slouch.
Even going to the 2323 pistons will make a big difference in what you can put in it.
My $.02.
Old Apr 24, 2018 | 08:37 AM
76sbo's Avatar
Is there a specific brand and part number for the 2323 pistons? Oldsmobile knowledge and machinist are pretty much non existent where I live. My knowledge is limited also.
Old Apr 24, 2018 | 08:53 AM
Sealed Power L2323F or Speed Pro L2323F. Made by Federal Mogul and marketed under both of those names.
Old Apr 24, 2018 | 11:45 AM
What are the specs of the current E-brock cam?
Old Apr 24, 2018 | 12:27 PM
76sbo's Avatar
It is the Performer Plus 288/298 472/496
thanks
Old Apr 24, 2018 | 04:55 PM
cutlassefi's Avatar
What was already said here is correct. Pretty much no matter what you do short of raising compression would be a futile effort.
Pistons/compression first, then address the other stuff.
Old Apr 25, 2018 | 12:03 AM
thanks
Looks like those duration numbers are the advertised figures. That cam comes in at 214/224 @ 0.050, I think. So you may already have too much cam for your current compression. I'll concur with the others here -- you certainly don't want to go bigger without increasing the compression.
Old Apr 25, 2018 | 03:35 AM
My442's Avatar
I built my 455 with the same pistons, and with the combo I picked, ended up at approx. 9.8 to 1.
Used a cam with 226/230 at 110 LSA.
Perfect for the street.
Old Apr 25, 2018 | 06:55 AM
76sbo's Avatar
Thank you for the replies. I will order the pistons and rings today. I have always thought the car was pretty slow for a 455. Again Thank You. So my next question would be with my current parts and the 2323 pistons, would i still use the .027 head gaskets or the gaskets that came with the FelPro gasket kit?
Also, cutlassefi, would you recommend a better cam grind for this setup?
Old Apr 26, 2018 | 04:21 AM
cutlassefi's Avatar
Yes I do. And why the 2323’s? Use the Wiseco instead, better piston and not that much more $$.
Old Apr 26, 2018 | 07:56 AM
76sbo's Avatar
PM sent to cutlassefi
Old Apr 28, 2018 | 12:08 AM
73aussie455's Avatar
Acceleratii maxim rapidus
I'm doing a very similar refresh on my '73 455 at the moment.
I bought these pistons .030" over, but if your donk only has 60K miles you may get away with std size???
I don't know if that's a thing or not to change piston/ rings without boring or at least honing the cylinders.
Wiseco;
https://kmjperformance.com/wiseco-pt...ore-4-125.html
bainer1290
Jul 11, 2014 07:07 AM
rookieoldsguy72
Jan 1, 2014 06:51 AM
celticsam
Dec 21, 2013 06:05 PM
drjr56
Aug 29, 2012 11:54 PM
VinMichael
Apr 4, 2012 07:10 PM
