Street 455 cam choice
Old Dec 14, 2013 | 06:38 AM
celticsam's Avatar
I am building a very low mileage (45K) 1970 455 high compression engine out of a Hearst. The engine will be driven on the street frequently, with 1 or 2 trips to a track a year. While the stock cam is fine, I was wondering if a more modern cam would improve both power and mileage. Any suggestions on the cam, and would I be able to keep the stock non-adjustable rockers and such, or would that need to be converted as well. Other info, the car is an 85 Cutlass, I will be running a fresh turbo 350 transmission (built for the torque), and, for now...the stock rear...or at least until it goes. The rear will eventually be replaced with a 3.08ish rear, type to be determined.
Old Dec 14, 2013 | 06:47 AM
celticsam's Avatar
Almost forgot...E-heads.
Neil
Old Dec 14, 2013 | 06:52 AM
cutlassefi's Avatar
Erson Hi Flow 1. 228/228@.050 with .504 lift.
It'll work with the stock rocker setup but seriously consider replacing the springs no matter what. It may only have 45k on it but that means its been sitting with same valves open for more time than the others and they're still 43 years old.
Thanks.
Old Dec 21, 2013 | 06:05 PM
odddoylerules's Avatar
mondello grind JM-20-22 (i think) was great in my low compression 66, pulled like a tugboat from any rpm
Schne442
Feb 14, 2014 10:08 AM
oldduck1
Nov 1, 2013 09:47 AM
hazzmatte
Oct 13, 2010 06:19 PM
cts-v
Dec 30, 2008 07:34 PM
geckonz08
Jul 23, 2008 05:52 AM
