rebuilt 455 startup
Old Apr 28, 2018 | 07:32 PM
jordan845's Avatar
rebuilt 455 startup
i rebuilt this engine but i cann't get it to start up , but it has back fire 2 time . help please
Old Apr 29, 2018 | 05:22 AM
rustyroger's Avatar
'87 Delta 88 Royale
We need a lot more information. But first guess is you have an ignition problem. Double check the timing and make sure the plug wires are in the correct order. You do know the distributor rotates anti-clockwise?.
Roger.
Old Apr 29, 2018 | 05:42 AM
RetroRanger's Avatar
72 Olds CS
Best first guess on little info is the distributor is 180 degrees out. If your getting spark an fuel re stab the dizzy 180 degrees and see if that works
Old Apr 29, 2018 | 04:24 PM
jordan845's Avatar
I tried turning 180 degrees and i tried anther distributor both are HEI . I don't think I'm get fire . I tried to check for fire with a test light . My wire going to the distributor is hot . i have it coming from my fuse box pigy back with my fuel pump . I thought of running it on a line by it seft .
Old Apr 29, 2018 | 04:28 PM
jordan845's Avatar
Yes i have my plug wires going counter clockwise . It in a 68 442 .
Old Apr 29, 2018 | 04:31 PM
Run a jumper wire to batt terminal on the hei, just remember to turn the engine off you need to remove the jumper. If you have a tach hooked up disconnect it for now. If its back fired you have spark. Make sure you have the wiring order correct, wired CCW. Ensure your rotor is pointing to the #1 distributor cap post when the #1 cylinder is at TDC.
gbledsoe3
Feb 17, 2018 09:38 AM
CLcutlass
Jul 13, 2013 07:35 AM
boondocker
Aug 24, 2011 05:33 AM
ITS68
Aug 29, 2010 03:15 PM
case2273
Jul 15, 2009 02:00 PM
