B-heads 66 toro 425
Old May 1, 2018 | 09:44 AM
deadeyejedi's Avatar
B-heads 66 toro 425
Anyone tell me about cam bank angle ? Everything I read says b heads will work on a 455.my block has 39 degree cam bank angle and I believe these heads came from a 45 degree 425 block . I placed the head on my block put a rocker ,push rod ,and lifter in . And it appears the push rod is very close to the wall of the hole at the bottom of the head(1/16th of an inch maybe). Shouldn’t the push rod come out the bottom dead center of that hole?ive read that you can open up the size of the push rod hole in these heads for clearance at the machine shop. Is this acceptable or did I throw my money away?
Old May 1, 2018 | 10:58 AM
You can open the holes if needed. This is not a big deal.
Old May 1, 2018 | 01:20 PM
Great that’s what I needed to hear thanks joe
L77F85
Sep 4, 2016 03:42 PM
Paxtonshelby
Dec 29, 2015 04:58 PM
lowkey235
Aug 12, 2013 06:11 AM
vistacruiser1971
Dec 27, 2012 07:35 AM
<Fuelie 425>
Jul 15, 2004 04:29 AM
