371 oil galley plugs /restrictor plugs
Old Sep 21, 2015 | 05:31 AM
MrGasser's Avatar
Hi, I've already looked at several threads but maybe there's some (new) information out there...
I just put in a rebuild 371 (1960) and and experienced problems with oil pressure on the drivers side oil valley along with a rattling sound from the lifters on this side. When pulling the distributor I noticed that the rear oil galley plug is missing...
As I am from overseas (Germany) I have to be sure to order the correct parts now and hope that someone can help me.
I would like to know:
1. this missing galley plug, is it possible that the missing galley plug caused any damage to the new reubuild motor already? We only fired it up several times but it has not been running much so far.
2. Is it just one oil galley plug or are there any other I need to check for as well? I am pretty sure its just the one on the rear.
3. Which size is it and will I need one with a drilled hole (diameter?)
Any pics?
4. Has anyone managed to install it without pulling the engine? I noticed in several threads some people made it but not sure it was like for the 455 and I wonder if there is any difference for my 371
Any pictures / drawings of the location, of the valley plug itself or installaton of it are very much appreciated.
Old Sep 23, 2015 | 07:42 AM
Tedd Thompson's Avatar
Give Tony a call at Ross Racing engines he is the guru of first generation Old's engines and I'm sure he will know for sure.... Tedd.....https://rossracingengines.oursafeserver.com/
Convertcrazed
Sep 17, 2015 03:31 PM
RandyS
Dec 26, 2013 10:57 AM
Sampson
Dec 5, 2013 03:09 PM
OldsMotion
Jan 12, 2013 12:50 PM
RAMBOW
Dec 8, 2012 08:39 AM
