Head torque specs
Old Sep 29, 2024 | 10:23 AM
pgapapa46's Avatar
Head torque specs
1973 Toro 455 needs head gasket, anyone have bolt tightening specs for it, Thanks in advance
Old Sep 30, 2024 | 04:21 AM
BillK's Avatar
There is a "sticky" at the top of this forum with the information you need.
Old Sep 30, 2024 | 04:33 AM
pgapapa46's Avatar
Thanks you very much...........
Old Sep 30, 2024 | 04:34 AM
pgapapa46's Avatar
FUEL PUMP
Fuel pump to block bolt and nut............................25
Fuel pump eccentric to camshaft............................65
EXHAUST SYSTEM...........................................1 5-20
ENGINE
Crankshaft bearing cap bolts (400 & 425 engines)..........120
Crankshaft bearing cap bolts # 1,2,3,4 (330 engine)........80
Crankshaft bearing cap #5 (330 engine)....................120
Cylinder head to block.....................................80 **
Connecting rod nuts........................................42
Oil pump to bearing cap bolts..............................35
Oil pump cover to pump bolts................................8
Rocker arm studs to head...................................35
Rocker Arm Pivot Bolt to Head..............................25 ***
Rocker arm nuts to studs...................................25
Valve cover bolts...........................................7
Oil pan bolts (5/16")......................................15
Oil Pan Bolts (5/16).......................................12 ***
Oil pan bolts (1/4")........................................8
Oil pan drain plug.........................................50
Oil Pan Drain Plug.........................................30 ***
Crankshaft balancer or hub to crankshaft bolt..............50
Crankshaft Balancer or hub to crankshaft bolt.............120 ***
Oil filter element to base.................................20
Oil filter assembly to cylinder block bolts................35
Front cover to cylinder block bolts (3/8").................35
Front cover to cylinder block bolts (5/16")................25
Fan driven pulley to hub bolts.............................20
Fan driving pulley to hub or balancer bolts................20
Water pump to front cover bolts............................13
Water outlet to manifold bolts.............................20
Intake manifold to cylinder head bolts.....................35 **
Intake manifold baffle to cylinder block bolts..............8
Exhaust manifold to cylinder head bolts....................25
Carburetor to intake manifold bolts and nuts...............15
Tube and plate to intake manifold bolts....................15
Air cleaner to carburetor stud..............................5
Motor mount to cylinder block bolts........................50
Starter to cylinder block bolts............................35
Starter brace to cylinder block bolt.......................25
Starter brace to starter bolt..............................15
Distributor clamp to cylinder block bolt...................14
Distributor Clamp to Cylinder Block Bolt...................17 ***
Spark plugs............................................. ...35
Coil to intake manifold bolt...............................15
TURBO HYDRAMATIC TRANSMISSION
Transmission case to cylinder block bolts..................30
Converter cooler pan to transmission case..................12
Cooler lines to transmission case..........................35
Flywheel to converter attatching bolts.....................35
Support assembly to transmission...........................35
Propeller shaft to rear companion flange...................16
Governer cover to transmission case........................20
Modulator to transmission case.............................20
Rear extension housing to transmission case................25
Bottom pan to transmission case............................13
Parking pawl guide to transmission case....................20
Detent solenoid to transmission case.......................14
Valve body to transmission case............................10
Rear servo cover to transmission case......................20
Pump assembly to transmission case.........................25
Case center support to transmission case...................25
Pump body to pump cover attaching bolts....................20
FOUR SPEED MANUAL TRANSMISSION
Side cover bolts...........................................20
Transmission to engine bolts...............................65
Cross support bar brackets to frame........................35
Transmission mount to cross support bar....................50
Propeller shaft U-bolt nuts................................14
Bearing retainer to transmission case bolts................20
Rear bearing retainer to transmision bolts:
Three upper............................................. 25
Three lower............................................. 35
CLUTCH
Clutch cover............................................. ..17
Flywheel housing to block..................................30
Ball stud equalizer to engine..............................28
Ball stud equalizer to frame...............................22
Clutch release fork ball stud..............................45
Shift equalizer rod to transmission........................18
Clutch pedal pivot bolt nut................................20
** = Clean and dip entire bolt in engine oil before tightening
*** = 455, 350 and post '67 400
RetroRanger is offline Report Post
Quote Multi Quote Quick Reply
Old Sep 30, 2024 | 05:07 AM
While this table provides the value, it doesn't provide the torque pattern. You really need to get a 1973 Chassis Service Manual if you plan to work on the car like this. At this moment there are several on ebay with the least expensive one currently at $10.99.
Old Sep 30, 2024 | 05:32 AM
pgapapa46's Avatar
Old Oct 2, 2024 | 12:28 PM
shiftbyear's Avatar
Note the ** for bolts requiring oil during installation. Although it calls out dipping, lightly oiling the friction contact surfaces with a brush (under the bolt head and threads) works fine. Make sure all bolts and holes are cleaned and threads chased for proper torque clamping. Most gasket fails are due to improper cleaning and torquing procedures.
Bullwinkle
Jul 21, 2024 08:55 PM
lemoldsnut
Mar 23, 2017 11:25 AM
Crockett 999
Jan 5, 2015 03:22 AM
442scotty
Aug 10, 2013 10:34 AM
69350rocket
Apr 5, 2011 11:30 AM
