Stupid Head Gaskets !!
Old Aug 9, 2013 | 06:54 PM
442scotty's Avatar
Anyone had problems with Felpro Head gaskets leaking externally (mine at the back side on both) using ARP 7/16 bolts ( 70 455 Olds).
This is the second time on 2 different engines. I assembled the first one and the Engine shop the latest one. Went with a different brand gasket on the first one which solved the problem(Company now bankrupt and I cant recall the brand but they were not cheap). Not even sure I got 1K miles on it this time before they started leaking.
Losing 1/2 qt of oil every 400 miles from the passenger rear side and a jug of coolant every 1000 miles or so from the drivers rear side. Took a while to figure out where it was coming from and its for sure the head gaskets.
Anyone had success resealing gaskets by retorquing the heads?
Nothing appears to be getting in the Oil or cylinders.
Geez what a PO
Old Aug 9, 2013 | 08:05 PM
Hmmmm, never had that happen.
Old Aug 9, 2013 | 08:32 PM
Charlie Jones's Avatar
Phantom Phixer
Re-torqueing a head gasket after the engine has been warmed up and ran was practically a requirement 40 years ago.
I still like to do it when practical, although most head gasket makers say it isn't necessary.
Of course I'm sure you know that the head bolts must be torqued in the proper sequence. Starting from the center and working out.
Another little trick that I picked up over the years was to torque all the head bolts to one third of their final torque. Then torque them to two-thirds of their final torque. Then torque them to their final recommended torque.
And finally, go around the torque pattern again just to make sure you didn't miss a bolt.
Did you check your heads with a straightedge and a .001 feeler guage?
Old Aug 10, 2013 | 05:02 AM
442scotty's Avatar
The current engine was done by a local builder with a good rep so Im not sure what he did. Im hoping for a miracle but know in the back of my mind that the heads are gonna have to come off... Don't mind pulling them..its the readjusting the valves that I hate the most..
Old Aug 10, 2013 | 05:20 AM
dc2x4drvr's Avatar
I had the same problem, turned out the machine shop left the decks and heads too rough for a good seal. I had to pull the motor down, and resurface the decks and heads. I'm using Cometic head gaskets.
Old Aug 10, 2013 | 07:57 AM
svnt442's Avatar
Never heard of that one before. Fel-Pro has a great reputation for a good reason.....they make a quality product. I wouldn't hesitate to use them for anything I would want to put together.
Old Aug 10, 2013 | 10:30 AM
Phantom Phixer
It's not really going to cost you anything to re-torque the heads. Except for a little time. You may get lucky and solve your problem.
If you have solid lifters then I would definiately check the valve lash, and re- adjust if necessary.
Old Aug 10, 2013 | 10:34 AM
s i 442's Avatar
Oldsmobile enthusiast
Must be an engine problem because Felpro is the go to gasket.
Adjusting the valves???
auto_editor
Apr 26, 2013 05:19 PM
MDchanic
Mar 27, 2012 07:54 PM
Tedd Thompson
Sep 24, 2010 07:32 AM
gearheads78
Dec 18, 2009 06:15 AM
Deltarocket
Jun 5, 2007 06:54 AM
