Cracked rocker arm, but why?
Hi guys.
Story is. First attempt to first start up after rebuild revealed a leaking fuel pump.
Decks on block and both heads have been ground. All new bearings and a new cam.
What would cause a cracked rocker arm? It was not cracked before first attempt to start it so I guess it cracked during cranking the engine. Second attempt was obviously aborted when I noticed this.
My rocker arm setup on both heads has shims and I am thinking of putting in shims to match the amount that the engine builder removed when grounding.
Any ideas?
Thanks, Søren.
Any ideas?
Thanks, Søren.
J/O
Apr 25, 2012 03:09 PM
KRICHEN922
Dec 5, 2009 09:39 AM
