Cracked rocker arm, but why?
Old Jun 28, 2015 | 01:34 PM
Sircajun's Avatar
Hi guys.
Story is. First attempt to first start up after rebuild revealed a leaking fuel pump.
Decks on block and both heads have been ground. All new bearings and a new cam.
What would cause a cracked rocker arm? It was not cracked before first attempt to start it so I guess it cracked during cranking the engine. Second attempt was obviously aborted when I noticed this.
My rocker arm setup on both heads has shims and I am thinking of putting in shims to match the amount that the engine builder removed when grounding.
Any ideas?
Thanks, Søren.
Old Jun 28, 2015 | 05:11 PM
scrappie's Avatar
Your probably gonna need to check the preload.
Old Jun 28, 2015 | 06:07 PM
The only thing I can say is look at the valve geometry, coil bind, pushrod length...
Old Jun 28, 2015 | 09:05 PM
gs72's Avatar
72Cutlass S
It's probably the plug wire that is between the rocker and pushrod. Lol
Old Jun 29, 2015 | 01:01 PM
cjsdad's Avatar
This is one of the reasons I never looked back when I left Bakersfield!!!
Old Jun 30, 2015 | 01:58 PM
Sircajun's Avatar
I managed to get 30 minuttes of garage time put in this evening
Push rods on intake valves are all bend! On the exhaust they are ok...
Old Jun 30, 2015 | 03:07 PM
How much did you take off the heads and block? Are the valves hitting the pistons? Are the springs bottoming out? What was your preload on the rockers?
Old Jun 30, 2015 | 04:28 PM
TripDeuces's Avatar
New cam = new springs? Did you check installed height and coil bind?
Bent pushrods sounds like coil bind to me.
Old Jun 30, 2015 | 05:21 PM
4speed455's Avatar
Maybe the pushrods are too long? Did you measure them and replace or reuse the old ones?
Old Jul 2, 2015 | 11:43 AM
Seff's Avatar
I have a pushrod gauge I can mail you real quick if that's needed.
J/O
Apr 25, 2012 03:09 PM
Dan K
Dec 13, 2011 11:03 AM
russell-t
Sep 22, 2011 06:37 PM
IZAOLDS
Oct 16, 2010 11:43 AM
KRICHEN922
Dec 5, 2009 09:39 AM
