66 Toronado engine help please
Old Sep 18, 2024 | 05:55 AM
Slick66's Avatar
Slick66
1966 Olds Toronado engine
Looking for a running 1966 Toronado engine or advice on any other engine to fit in a 66 Toro.
Old Sep 18, 2024 | 06:15 AM
Any second gen olds V8 should fit in there provided you have the correct oil pan. To be correct, you want a 66 425.
Old Sep 18, 2024 | 06:25 AM
Slick66's Avatar
Slick66
Thanks Koda, actually the origional 425 is in the car now. Problem is I've owned and been driving it for about 5 months. Yesterday I couldn't break 35 mph. The engine has some serious blowby. 150 compression in all cylinders except #7 has 30. Also I put air in that cylinder with the piston at top dead center and could hear air rushing out of the exhaust. 2 weeks ago it was having problems exceeding 60 mph. It doesn't have a tach. Any idea what is going on?
Old Sep 18, 2024 | 06:48 AM
67OAI's Avatar
Old(s)GuysRule
Could be as little as a broken valve spring or as much as a badly burned valve seat according to what you have posted. I would pull the affected cylinder's valve cover and check for a broken valve spring first.
Old Sep 18, 2024 | 07:04 AM
Slick66's Avatar
Slick66
Thanks thats what other people I've talked to are also saying. I've never torn an engine down before but I'm very mechanically inclined. So it does have alot of blowby, smoke and oil comes out of the dipstick, filler tube and breather. Taking the heads off is something that I can handle especially since someone with the knowledge says he'll help me out. My other concern would be the rings though. I guess what I'm asking is what are the odds that if it is a spring or valve issue, that I would also have what appear to be excessive blowby symptoms?
Old Sep 18, 2024 | 09:12 AM
Sugar Bear's Avatar
If that engine sat for a long time the piston rings may be clogged and/or sticking. If it was mine I'd soak the rings for a week or two before condemning them re: the blowby.
#7 blowing air out the exhaust is an exhaust valve related problem. As suggested pull the valve cover to see what is happening in there e.g., the mentioned possible broken spring...seen it before.
As for no power is the distributor by chance loose and rotating causing the timing to retard? Put a vacuum gauge on it to check for an internally collapsed exhaust system. Air intake is unobstructed?
Will it rev without a load?
Old Sep 18, 2024 | 10:08 AM
Slick66's Avatar
Slick66
Thanks for your input. So I have soaked that piston with GM top end cleaner. I've soaked it with MMO for a few days multiple times but not weeks so ill try that. Dostrubutor os not loose but I did change the coil to a blue streak and it was directly after that there was a noticeable miss. I put the old one back on and the miss continued and got gradually worse. Put the bluestreak back on and the symptoms continued. The distributor is not loose, cap, rotor and points look new. There is a type of corrosion on the springs and weights though. I changed the wires and plugs properly gapped. .035. It revs fine without a load when its warmed up. Exhaust is now true dual to oversized perforated cherry bomb glasspacks. I took off a rotten muffler. The air to the carb is not restricted. I had the valve covers off 3 months ago bit of course this problem was not occurring then.
Old Sep 18, 2024 | 10:13 AM
Sugar Bear's Avatar
Soak all of the cylinders not just one.
Old Sep 18, 2024 | 10:15 AM
Slick66's Avatar
Slick66
Ok I will do that for much longer thank you.
Old Sep 18, 2024 | 11:48 AM
... and if that engine proves to be unusable as is, I think you'll be ahead of the game to rebuild it rather than swapping something else in.
Old Sep 18, 2024 | 12:08 PM
Sugar Bear's Avatar
Soaking the rings is an attempt at reducing the blowby on all of the cylinders, it may or may not help. It is unlikely to help with #7's low compression, as mentioned earlier that is valve related. If you can zero in on the problem it may reduce the amount of repair needed e.g., doing a valve job vs. a full rebuild.
Old Sep 18, 2024 | 12:27 PM
Check out the valves then do an Italian tuneup.
Old Sep 18, 2024 | 12:38 PM
Slick66's Avatar
Slick66
If I'm going to rebuild it myself, then what am I in for overall if you don't mind?
Old Sep 18, 2024 | 01:27 PM
Depends on several variables: what quality you want, how much work you're willing to DIY, condition of the engine to begin with, machine work required, intended use for vehicle, etc.
A Kanter overhaul kit begins at ~$1800.
Old Sep 18, 2024 | 03:28 PM
Slick66's Avatar
Slick66
Here she is by the way
Old Sep 18, 2024 | 04:56 PM
Sugar Bear's Avatar
Nice looking ride...!
Was re-reading post #7 again, often problems are where the last work was done. Check the wiring on the primary on the coil to confirm that the - goes to the distributor/black wire. Wires from the ignition switch and the starter go to the coil +. Check that the secondary/high voltage coil wire ends are making good contact, try another coil secondary/high voltage wire if you have one. Often problems are where the last work was done.
About rebuilding the current engine, I agree with doing that vs. another engine. 39 degree camshaft and .921 lifters may be harder to find, other than that it's pretty straight forward.
Cylinder wall scoring was mentioned in another post. Do you have pics?
Old Sep 18, 2024 | 05:26 PM
Slick66's Avatar
Slick66
Scoring too difficult to even see in the borescope screen through a camera
So they are there belive it or not. You just can't really see them through the phone camera. They are pretty light there is one line resembling a bit of a heavier scuff.
Old Sep 18, 2024 | 07:13 PM
Sugar Bear's Avatar
Hard to tell from the pics, from them it looks very minor...
Is the top of the piston pitted or is that just the picture quality?
Old Sep 18, 2024 | 07:16 PM
Slick66's Avatar
Slick66
it looks to me like an even glazing of carbon. There have been times where some of that has been missing and exposed the piston. From what I've seen of that the metal looks in good shape. This is why even though I have such immense blowby, I'm wondering if something other than rings has any conceivable way to contribute to it.
Old Sep 18, 2024 | 08:08 PM
Sugar Bear's Avatar
A plugged breather system can cause pressure buildup. Rings are the most likely culprit.
Adding something such as MMO to the oil will also help to free stuck/clogged oil scraper rings. If you drive it push it hard uphill and let it coast at high vacuum downhill, repeat, repeat and repeat.
If it is stuck rings hopefully you can free them up, sometime it works sometime it doesn't.
Old Sep 18, 2024 | 08:25 PM
Slick66's Avatar
Slick66
Gotcha and there is something else to note. The intake manifold started to leak oil at the same time I first noticed the miss. Is it possible that the intake manifold is cloged at the exhaust crossover?
Old Sep 18, 2024 | 08:54 PM
Unlikely and that won't pressurize like that. You've got either mad blow by or bad breather system or both. Recommend you pull out the pcv valve and make sure it rattles. Try running without it in the garage, just a hole in the valve cover. Ideally, it should be sucking air in a bit as the intake on the other end sucks it. It could, however, be pressurizing so much that it is pushing fumes out. Or, it could be doing nothing at all and the PCV system is the problem all along. I really think you'll get fumes pushing out of the PCV valve hole when you fire it up without it in there. Should stop the oil pushing out, but you would still have to fix the blowby. Would rule out the PCV, though.
Old Sep 19, 2024 | 05:48 AM
ROCKETMAN269V's Avatar
......... 39 degree camshaft and .921 lifters may be harder to find...........
The 39 deg. camshaft is the more common one; used in all '68 and newer engines.
Old Sep 19, 2024 | 07:08 AM
Sugar Bear's Avatar
Thanks ROCKETMAN for the correction!
Old Sep 19, 2024 | 07:31 AM
67OAI's Avatar
Old(s)GuysRule
As ROCKETMAN said, the 39 degree camshaft is the more common one. Finding good aftermarket .921" diameter lifters is the difficult hurdle here; I would check with Mark Remmel, cutlassefi, for replacements or have my originals refaced.
Old Sep 19, 2024 | 10:23 AM
jaunty75's Avatar
Actually, you probably want a 66 425 out of another Toronado. The Toronado version of the 425 engine, which was available only for the Toronado, had a special high-lift camshaft, larger diameter lifters, bigger intake ports in the head, and 2.06-inch intake valves. This gave it 385 hp (which was considered a conservative rating), which was listed as 10 hp more than the next engine "down," a 375 hp Starfire V-8.
Keep in mind that the Toronado is a heavy car, weighing almost 200 lbs more on average than the next Olds on the list, the 98. While certainly other engines would fit, you don't necessarily want them if you want your Toro to drive and handle as originally designed and as you would expect.
Old Sep 19, 2024 | 10:30 AM
Slick66's Avatar
Slick66
Thank you ROCKETMAN. So you're saying 68 and up. I'm assuming then the Toro 455 uses the same cam and lifters as the Toro 425?
Old Sep 19, 2024 | 10:47 AM
Slick66's Avatar
Slick66
Hi Jaunty, so ideally I would want the original engine to be rebuilt. I have talked to a few rebuilders at this point. The last one mentioned that the compression should be lowered to 9. something due to me wanting to run the car off of 93 octane. While the existing engine was running at the peak performance I was able to get out of it, it did ping but under heavy load only. I can understand why he thought that would be the best course of action however he also mentioned that it would be doggish. I do belive that some adjustments should be made although I dont like the idea of the engine producing less power. My dilemma here would be justifying the cost. They all want between 12 and 14 thousand although that would include a recore of the radiator and painting the engine in one case. Now I'm not attached to the radiator either. If I could find a suitable replacement I would just put that in myself. I have entertained the idea of water injection if this is the only true way to keep the 10.5 to 1compression without retarding the timing.
Old Sep 19, 2024 | 11:24 AM
Slick66's Avatar
Slick66
For that matter does anyone have advice for adding water injection to reduce pinging. I would like the engine to at least make the power it once did without complications due to using 93 10%ethanol.
Old Sep 19, 2024 | 11:46 AM
Slick66's Avatar
Slick66
Yeah I just pulled off the pcv valve and ran it until it warmed up. Lots if smoke comes out of the hole.
Old Sep 19, 2024 | 12:32 PM
  #31
Slick66's Avatar
Slick66
So its very difficult to show the amout of smoke on the camera but the haziness of the pictures is acurate to the amont of smoke in the garage. All this and little to nothing comes out of the tailpipes unless hard acceleration.
Old Sep 19, 2024 | 12:40 PM
  #32
I moved this out of the parts wanted forum.
Old Sep 19, 2024 | 12:41 PM
  #33
Slick66's Avatar
Slick66
Ok sorry I didn't realize I would get this much helpful advice when I posted it there.
Old Sep 19, 2024 | 01:23 PM
  #34
ourkid2000's Avatar
Here's a link to my recent thread about having one cylinder down on compression on a '66 Toronado. Mine came back........Seafoam seemed to do the trick better than the MMO. However, I did notice that your PSI didn't come up very much after adding oil and that's something that didn't happen with mine (oil helped a lot more in my case). Mine was definitely stuck rings. I tested it again a few days ago, still up in the mid 185's.
https://classicoldsmobile.com/forums...-425-a-181426/
Old Sep 19, 2024 | 10:47 PM
  #35
69CSHC's Avatar
The 425 is Oldsmobile's greatest engine. Specifically the one in your car. If there is one Olds engine that should be rebuilt its that one.
That is precisely why I torture myself with constant worry about highest octane at all times plus octane booster. As well as babying my car above 2000 rpm on anything but a level or declining surface. I want her at her factory maximum.
As both Koda and jaunty75 said. There is a wide selection of engines that will fit, and big block torque is best. You need it to get that behemoth off the schneid. The ideal compromise if you choose not to go big block again is the 403. It has big block torque when true dual exhaust and of course powered the 1977 and 1978 Toronado. Which weighed 250-330 lbs more than the 66. But performance will suffer very badly. Stock to stock the 403 powered Toro is 4-5 seconds slower to 60 MPH.
P.S. your ride is beautiful in and out. Shocking to me how good it looks when considering how shot the engine seems to be. The 66 Toro's compression ratio on paper is 10.5:1 the highest for any Olds engine 1964-1970. My 350s compression ratio on paper is 10.25:1 tested at 110,000 miles she ranged 180-190 psi. And is still running lights out at around 140,000 miles. She doesn't obviously smoke but she definitely eats oil and has some slight lifter tick, that seems to come and go...
(150 psi is great, but on a low compression engine.)
Old Sep 20, 2024 | 01:39 AM
  #36
Slick66's Avatar
Slick66
Thank you 69CSHC. Between people like you and all of the research I've done, I'm convinced that this engine really is overall the best Olds engine at least stock. On this pinging thing, I did look into water injection although I'm not sure if thats really the best route. My concern is problems that might bring like somehow getting actual water in the cylinder. Most likely I'm going to have this engine rebuilt rather than build it myself, I simply just want the best bang out of it for the buck. Ive swapped engines and transmissions before but I have no practical experience with the internals. The car has one of the best transmissions ever built also and so far so good with that.
Old Sep 20, 2024 | 04:40 AM
  #37
jollyolds's Avatar
ive seen seafoam and marvel mystery oil work wonders on stuck rings and lifters-also have u thought of cracks anywhere??
compression RATIO and compression PRESSURE are 2 different things
Old Sep 20, 2024 | 07:12 AM
  #38
Slick66's Avatar
Slick66
I've thought of cracks yes but I see none and ive spent alot of time looking. If there were any they'd have to be on the inside.
Old Sep 20, 2024 | 08:17 AM
  #39
OLDSter Ralph's Avatar
Have you actually diagnosed why you have low cylinder pressure in one cylinder / Until you zero in on the problem, you are just guessing. Do you have stuck rings or leaking valves ? How many thousand miles on the engine ?
As far as "advertised compression ratio", actual compression ratio's are generally lower (almost always). Unless you can tell us how far the piston sits down in the bore, and what the combustion chamber volume is, you're just guessing.
Olds engines are very rugged. Take the car to a competent mechanic and fix the problem. You may not need a complete overhaul.
Old Sep 20, 2024 | 08:42 AM
  #40
Sugar Bear's Avatar
Cracked blocks/heads etc. aren't that common. Symptom are overheating, white smoke from the exhaust and coolant loss both externally and/or internally.
From a cracked casting perspective my $ is on it's fine.
