66 442 Oil pump and rear main
Old Jun 6, 2010 | 10:57 AM
4-Speed's Avatar
Any recommendations on an oil pump and rear main seal for 66 442 400?
Thanks-
Old Jun 7, 2010 | 07:40 AM
442Harv's Avatar
Melling oil pump, and a Ford 460 rubber seal.
Old Jun 7, 2010 | 07:47 AM
citcapp's Avatar
X2 thats the way to go
Old Jun 7, 2010 | 03:34 PM
4-Speed's Avatar
Thanks guys... appreciated as always
Dave
Old Jun 22, 2010 | 09:56 PM
turnpike_cruiser's Avatar
Is the Ford 360 seal a direct replacement? Does anything need to be done to the crank or main seal area of the block?
Old Jun 23, 2010 | 10:56 AM
Run to Rund's Avatar
The Ford 460 seal is also marketed these days for Olds--a direct fit. The best version is Fel Pro 2948 made of fluoroelastomer.
Old Jun 23, 2010 | 11:07 AM
Oldsmaniac's Avatar
Direct fit but you need to install it the right way as one side is slightly different than the other. I use a Chiltons and they show the proper direction in the Ford engine section.
Old Jun 23, 2010 | 05:09 PM
4-Speed's Avatar
Thanks everyone, great info I for sure need-
Old Aug 2, 2010 | 06:29 PM
4-Speed's Avatar
Melling Oil pump?
Is this pump correct for my 66 442 400? Do I need the "high volume" for a stock engine?
http://cgi.ebay.com/ebaymotors/Oldsm...item5888d87bc9
Thanks-
Old Aug 2, 2010 | 11:54 PM
64Rocket's Avatar
Use the Melling M22f pump with the stock pan. Shim the pump spring .200 for better pressure.
The high volume pump is better suited for the after market oil pan.
Gene
Old Aug 3, 2010 | 02:18 AM
4-Speed's Avatar
Thanks Gene, what should I shim the pump with? Best source to buy the pump from?
Apprecaite the help-
Dave
Al2011
Aug 27, 2025 08:30 PM
Robert Kiedrowski
Apr 1, 2013 08:38 AM
friskyjake
May 19, 2012 07:35 AM
trackz man
Jul 17, 2011 10:08 PM
