Throttle Linkage Cutty "65
Old Jul 31, 2010 | 05:17 AM
panos's Avatar
Many of u alredy know that im going with a 455-th350 swap in my Cutlass ("65) that previously had a 350-st300 combo
The question is what kind of Throttle Linkage or even cable? can i use? i looked around at jegs-summit but is a jungle a lot to choose but i dont have any idea what would fit and what not,i would really appreciate it if someone had some tips or even better a link to the stuff i would need
the 455 im putting in has a 830 quick fuel(mech.sec.) and a performer with a 1/2" spacer ,i include a few pics to show u guys how it looks like now!the tranny switch at the pics has some serious side movement (axel) and i dont think i want to use it anymore.
Thanks in advance Panos
Old Jul 31, 2010 | 05:53 AM
442scotty's Avatar
Try a Lokar cable setup...pedal, cable and linkage. They only list it for chev but the setup is the same for all A bodies in 65-67. I want to get one eventually...
Old Jul 31, 2010 | 07:11 AM
Well, you certainly don't need the switch with a TH350. If you want to retain the stock accelerator pedal, you can do what I did on my 62 and buy linkage parts from McMaster Carr to fabricate a new throttle rod. The TH350 kickdown cable needs to be adapted to the carb. The easiest way is to find the cable and carb bracket from a late 70s Olds and use those.
Old Jul 31, 2010 | 07:23 AM
panos's Avatar
Well is nothing "easy" to find espacially here in Sweden lol I choose not to have a kickdown at the new trans so thats a problem less would something like that work?what do u guys think?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Jul 31, 2010 | 07:51 AM
The cable will work, but obviously you'll need to mount the new pedal in place of your old one. The other option is to build a linkage like I did:
Old Jul 31, 2010 | 09:37 AM
TripDeuces's Avatar
If you're getting rid of that mechanical linkage assembly I'd be interested in it!
Old Jul 31, 2010 | 10:02 AM
panos's Avatar
Are u reffering to mine or Joe´s pics? if its mine u want i ll be glad to send it to u when im done with everything but i hope u noticed i live in Sweden
Old Jul 31, 2010 | 11:02 AM
rocketraider's Avatar
Oldsdruid
I was gonna say, if that switch tests good, don't toss it!! Someone is always needing one and they fit all 65-67 except Toronado.
Old Jul 31, 2010 | 11:12 AM
panos's Avatar
Ok the switch works good actually,never had a problem with it.Didnt know that they were that popular though.
Old Jul 31, 2010 | 12:03 PM
The switches are "popular" because replacements are not available. Good used ones are always in demand.
Old Aug 4, 2010 | 05:19 PM
Warhead's Avatar
Have someone go to the wrecking yard here in the states, and get a cable and bracket, and pedal from a 307 buick Electra 4 door, or wagon. Pay em $20 to do it. Easy pull, easy install. Easy find, drill 3 small holes, 1 big one. Use the downshift cable for a Firebird (Vatojones carries new ones here) if yours is equipped with a Turbo 350 transmission. Throw the old junk on e-bay and let someone else fight with it for a change. That's what I did.
Just my opinion.
Jim
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
66starfire
Apr 29, 2007 08:46 PM
66starfire
Dec 21, 2006 01:57 PM
1964 oldsmobile 442
Sep 5, 2006 11:19 PM
