PerTronix Ignitor vs Ignitor II and III
#42
I'm afraid you've quite lost me then.
I would need a copy of the directions and photos of the starter to get any farther.
I can think of no way that a diode would allow you to replicate the action of the bypass wire, though you would probably be able to create a functional work-around for the lack of a bypass wire on an early car with one that was installed so as to allow current flow from the S terminal to the coil.
You're going to have to use a test light to check for voltage at different points in the circuit in order to determine where the problem is.
I hope that was a pretty big diode...
edit: I just realized that I described the opposite of the failure mode I assumed you have -
I said that you crank and it seems to be starting, then release the key and it doesn't run.
In fact, what you would have with the bypass wire disconnected is the condition where you crank and it doesn't quite start, but then if you release the key just right, it stumbles and runs.
#44
Okay, that is what I'd imagined.
So, if you did that, the bypass wire part should work.
Next, you need to determine which of the failure modes I described in my edit immediately above is the one you've got, and then do some testing.
One wire isn't supplying current when it's supposed, to - the question is which one?
#48
Eh. Takes 5 minutes.
Pull the two plugs and compare the wires to the wires on the pinout along the edges of the schematic in the CSM, to confirm that you've got the right one. Sometimes the colors can be deceiving, especially in the shadows under the dash.
edit: the pinout is on the bottom, just right of center - not the clearest, but it should help.
#52
Grrrrrrrrrr...
Ignition switch has thick red wire in,
Brown, Brown/White, Orange, Green, Purple, and Pink out.
You want Pink. Bottom of larger plug, Red diagonally next to it, Purple 2 spaces above it (diagonal to Red).
#55
Eureka! Took of the inline splice terminal (junk) and noticed the wire came out when I was taping it up. I looped the wire around the pink one (will solder tomorrow) and gave it a go. Sweet music to my ears!
Thanks so much Eric! I would gladly paypal you some funds for some brews if you want.
It is funny I have done more complicated work on my Diesel, I even converted my Subaru to run E85 but on this old gal I feel like I don't know anything.
amphicar770
October 31st, 2010 05:38 PM
