Name these parts
Old May 30th, 2011, 09:02 PM
jbevins's Avatar
Name these parts
I am doing a frame off on my 1970 olds 442 convertible, I noticed that under the rear springs there was what appeared to be a spacer under the rear springs I do not see anything of the sort in my assembly manual so I am suspicious that it was added by previous owner to raise the rear to accomidate 50 tires, any thoughts on this matter will be greatly appreciated.
Attached is a photo showing items in question.
Thanks,
Joe
jbevins is offline
Old May 31st, 2011, 04:19 AM
69442C's Avatar
Your suspicions are correct as these parts are aftermarket items for doing just as you described. If you are doing a factory stock restoration, leave these spacers in the used parts bin.
69442C is offline
Old May 31st, 2011, 08:20 AM
Thanks,
Joe
The back of that car must have been miles in the air - or the rear springs are completely shot.
joe_padavano is offline
Old May 31st, 2011, 07:56 PM
jbevins's Avatar
I believe the springs were that bad because the car for the most part was pretty level, a few years ago I replaced the springs in the front and did not notice much of a difference, though it seems to me that the car in general seemed high which would mean that the front was also raised, but the fact that I did not notice any change after replacing the front springs would prove otherwise.
If you go to the newbie section under newbie onboard I have some pictures posted, take a look and let me know what you think.
jbevins is offline
Old May 31st, 2011, 07:57 PM
jbevins's Avatar
Thanks for verifying what I thought was going on
jbevins is offline
Old June 6th, 2011, 11:24 AM
Not an Olds guy. Car guy
Project Grandpa's Avatar
You running 26's or 28's on that donk? I had those same spacers on my 69 396 Chevelle back in 1989. You could buy them at pretty much any parts store when A bodies were just cars. Gabriel used to make them among others.
Project Grandpa is offline
Old June 6th, 2011, 07:19 PM
jbevins's Avatar
I'm not sure what you are refering to as 26's or 28's
jbevins is offline
Old June 7th, 2011, 09:22 AM
Rim diameter
ryneves
February 9th, 2014 03:25 PM
Cutty72
August 29th, 2011 09:05 PM
lrbeavers
May 16th, 2011 11:20 AM
blue72regency
October 16th, 2007 05:27 AM
cooltat2z
July 12th, 2006 09:19 PM
Quick Reply: Name these parts
