Can you name these wires/plugs?
Old Aug 29, 2011 | 10:40 AM
Cutty72's Avatar
Been messing around with my 72 Cutlass and got the dash lights fixed and the original clock working again. While under the dash I noticed a whole bunch of plugs/wires/connectors that seemingly were attached to nothing.
I've attached pictures below - if anyone can provide some enlightenment (I know, cheesy joke) I'd appreciate it.
The first photo is this dangling from under the glove box
The second and third photos are the same bunch of wires just two different angles. This may be for the stereo. I have the original AM unit in there but it doesn't work. Potentially just not plugged in, haven't checked yet
The fourth one is a bit more difficult to see - the connectors are toward the upper left of the picture. This is closer to the drivers side.
The stuff that ain't working - cigarette lighter, AM radio - otherwise everything in the dash seems to be working. Any ideas?
Old Aug 29, 2011 | 12:21 PM
Wow, that's a bit of a mess.
First things first
The yellow wire is probably the original wire for your radio. If it's missing the connector. The 'plug' with the metal end is the antenna that comes from the front windshield and plugs into the back of the radio. (That would be a good reason you don't have reception on the radio). The bulb looks like the one that illuminates the 'heater' panel. If you turn on the park lights, this light should come on. If it goes on when you open the door without turning on the lights, it's part of the convenience light package.
The orange connector in the background could be the connection to the cigar lighter, or the connection to the maplight in the lower dash.
The relay that's hanging down could be the seat belt warning buzzer. Check by having someone hold the car in drive (has to be running) with the driver seatbelt undone.
Anyway, try that for starters. Does the one under the drivers dash have 2 prongs? If it does it might be for your emergency flashers. It's really hard to see in the pic.
Old Aug 29, 2011 | 04:37 PM
Lady72nRob71's Avatar
3rd pic - Seat belt warning buzzer with green and black wires going to it.
Possible old radio dial lamp hanging on gray wire
Yellow wire - to stock radio
4th pic - Connector with pink and orange wire is for TH400 tranny kickdown switch. On TH350 trannies, it is just not used. Yellow/black stripe wire and connector go to neutral switch on column - part of the seatbelt warning buzzer circuit.
Old Aug 29, 2011 | 08:41 PM
Originally Posted by Lady72nRob71
...............4th pic - Connector with pink and orange wire is for TH400 tranny kickdown switch. On TH350 trannies, it is just not used. Yellow/black stripe wire and connector go to neutral switch on column - part of the seatbelt warning buzzer circuit.
Rob, you sure? that looks a LOT like the connector for the emergency flasher - connectors are at 90° angles to each other.
Old Aug 29, 2011 | 08:49 PM
I would bet a beer on that one...
See it here just to the right of the column on the neutral switch:
http://farm4.static.flickr.com/3178/...dae378b0_b.jpg
It prevented the buzzer from sounding in any gear but forward.
Old Aug 29, 2011 | 08:54 PM
If I was down there, I'd buy you that beer - nice and cold. I always wondered why the seat belt buzzer would only sound in forward gears. Great pic BTW.
Old Aug 29, 2011 | 09:05 PM
oldspackrat's Avatar
That bulb could also be the one that illuminates the ash tray?. It pushes in & turns into a riveted hole on the passenger side of the ashtray. It can be a pita to install!
jeff in colorado
Jul 30, 2014 07:40 PM
Hawghead
Jul 18, 2014 12:51 PM
Finn5033
Mar 13, 2013 04:30 PM
Blue71Cutlass
Sep 18, 2011 10:59 AM
ELECMAN
Jul 26, 2010 05:10 AM
