Click Here
Wheels size
Old Dec 5, 2021 | 08:21 PM
J1978's Avatar
Wheels size
Hello I have a 1978 old ms delta 88 royale 2 door. Can anyone help me by telling me what’s the right size rim to mount and lug size Thanks
Old Dec 5, 2021 | 10:22 PM
Unfortunately, it depends. Standard equipment used a 5 x 4.75" bolt pattern with 7/16" studs. Cars with the optional HD brakes and suspension used a 5 x 5" bolt pattern with 1/2" studs.
Old Dec 6, 2021 | 09:57 AM
Joe, didn't all 77-85 B/C bodies use a 15" x 7" rim regardless of lug pattern? The OP might want to know that 4" backspacing and 0mm offset are what he should look for if he wants aftermarket wheels.
Old Dec 7, 2021 | 08:05 AM
J1978's Avatar
I put some 14” cutlass rims on my delta. There to small and it caused a rim to fall off. Do I am now looking for what the exact tire I need to use.
Old Dec 7, 2021 | 08:07 AM
J1978's Avatar
Also I’m just looking for some oem sized wheels. Aren’t they 15x6? And can anyone tell me what lug studs to get as well? I believe there 7/16
Old Dec 7, 2021 | 08:11 AM
My 1985 Deltas have 15x6 wheels. My B-body wagons came with 15x7.
Old Dec 7, 2021 | 03:37 PM
RetroRanger's Avatar
72 Olds CS
ouch thats sucks
if the rims fit on the studs then the bolt pattern is correct 5x4.75 as joe mentioned above (Standard equipment used a 5 x 4.75" bolt pattern with 7/16" studs.)
the rim may have fell off due to the wrong lug nuts, the lug nut needs to fit the stud hole taper to prevent it loosening up.
The overall tire diameter may have been smaller than typical but thats not why the rim fell off.
Old Dec 7, 2021 | 03:46 PM
72 Olds CS
check here for more info on the correct tires and sizes
https://classicoldsmobile.com/forums...5/#post1326427
J1978
Wheels and Tires
Nov 28, 2021 12:56 PM
oldrelics
Apr 16, 2014 09:40 PM
1968Cutlassfallbrook
Wheels and Tires
Oct 9, 2011 09:47 AM
arod40
Wheels and Tires
Jun 20, 2011 07:14 AM
Redog
Jun 9, 2011 09:24 PM
