recommendation for wheels on Scarebird conversion
Hello, I am going to be getting the front brakes on my 63 Dynamic converted. I was curious if anyone could recommend some simple wheels that will fit the conversion. I'm new to this part and there are a million options when I look up 15 inch 5X5 wheels.... Any help for a lost sould would be greatly appreciated.
Is this the kit your considering?
https://scarebird.com/index.php?rout...product_id=111
If so, you should be able to use any 15" rim with a 5x5" bolt pattern. You should probably get a wheel with 0mm offset and 4" backspacing. Here are some wheels:
https://www.summitracing.com/search/...0%2B4294920837
You'll also want to make sure the center bore diameter is large enough to clear the brake hub.
