Click Here
recommendation for wheels on Scarebird conversion
Old Jul 24, 2019 | 02:48 PM
adrianirish's Avatar
Hello, I am going to be getting the front brakes on my 63 Dynamic converted. I was curious if anyone could recommend some simple wheels that will fit the conversion. I'm new to this part and there are a million options when I look up 15 inch 5X5 wheels.... Any help for a lost sould would be greatly appreciated.
Old Jul 25, 2019 | 04:26 AM
Is this the kit your considering?
https://scarebird.com/index.php?rout...product_id=111
If so, you should be able to use any 15" rim with a 5x5" bolt pattern. You should probably get a wheel with 0mm offset and 4" backspacing. Here are some wheels:
https://www.summitracing.com/search/...0%2B4294920837
You'll also want to make sure the center bore diameter is large enough to clear the brake hub.
Old Jul 25, 2019 | 06:53 AM
Charlie Jones's Avatar
Phantom Phixer
Chevy or GMC half ton pickup truck wheels from 71 thru 86 work good .
That's what I have on my '63 .
Old Jul 25, 2019 | 08:26 AM
That's good to know Charlie, especially if you want OE steel rims. You could probably still find those in salvage yards pretty easily.
Old Jul 25, 2019 | 09:19 AM
The 15" wheels from a 1977-1990 B-body wagon will also work and should be plentiful.
Old Jul 25, 2019 | 09:56 AM
Don R.'s Avatar
I used 94-96 Chevy Caprice 9C1 cop wheels, 15 by 7 heavy duty, bolt right up and fit great. I used 1960 Buick wheel covers as they had no emblems.
Old Jul 25, 2019 | 10:15 AM
The B-body wagon wheels are dimensionally the same but without the holes.
Don R.
Wheels and Tires
Oct 27, 2014 11:44 AM
getawaycar
Wheels and Tires
Jun 3, 2013 07:28 AM
BruceC
May 13, 2013 11:02 AM
t bell
Aug 18, 2009 08:21 AM
64 Olds Dynamic 88
Apr 28, 2008 08:23 AM
