Click Here
Hub caps to fit 15” rims.
Old Jun 14, 2023 | 11:28 PM
5998DownUnder's Avatar
Old Jun 14, 2023 | 11:31 PM
Hi there,
can anyone tell me will these hub caps on my 14” rims fit 15” rims?
These rims have he 5 spring clips on the back.
14” tyres in 215/75/14 with white thin wall are not available in Australia but I can get 235/75/15 with the white thin wall hence the idea of going 15” but only if I can keep the caps.
Thank you.
Old Jun 15, 2023 | 02:52 AM
I doubt it. Hopefully somebody else can confirm this. They are pretty bad@$$!
Old Jun 15, 2023 | 07:43 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't believe there is any way you can make those fit. For the record, your 59 did not come with narrow whitewalls. Narrow whitewalls didn't really start until 1962. It probably came with a wide whitewall that was about 2 3/4 inches wide. Of course, you probably already know this.
Old Jun 15, 2023 | 07:55 AM
Kensey's Avatar
Wonder if you could mount the hubcap to a 15 inch beauty ring?
You my decapitate an innocent pedestrian testing this, but it's for the cause!
Just get very good quality beauty rings, not walmart.
Old Jun 15, 2023 | 08:21 AM
rocketraider's Avatar
Oldsdruid
Someone at 2009 National Meet had done that with a 1960. Guy had attached a 1960 14" full wheelcover to 15" trim rings. Don't know what trim rings were used.
Can't remember owner's name but the 1960 wheelcovers attach the same way as your 1959s.
Old Jun 15, 2023 | 07:11 PM
Decades ago JC Whitney used to sell adapter rings to allow the use of 14" hubcaps on 15" wheels. I have no idea if someone still sells them. A Google search turns up a lot of threads where people have used cheap trim rings as the adapter, per Glenn's comment above.
Old Jun 16, 2023 | 04:51 AM
Yes cannot bring myself to get rid of them.
Old Jun 16, 2023 | 04:55 AM
Thanks for the info on that I will have another look at going wider now for originality just that I did like the thin white line.
Ha ha no I actually did not know that about the wider white walls on my car originally. Happy to learn and thanks for that confirmation.
Old Jun 16, 2023 | 04:57 AM
Old Jun 16, 2023 | 04:58 AM
that’s a great idea I did not think of I might steal that one.
great idea thank you.
Old Jun 16, 2023 | 05:01 AM
Hi Joe,
I appreciate that information I will be following it up I’ll try EBay and check out the Google threads see if I can find those adapter rings.
Thanks.
Old Jun 16, 2023 | 05:06 AM
Let us know if you find some of those adapters on EvilBay.
58Oldsmobile88
Wheels and Tires
20
Dec 9, 2022 02:10 AM
4SPEED67
Wheels and Tires
Jun 22, 2021 07:40 AM
Dbechtel71
Sep 10, 2013 05:40 AM
tim72
Apr 21, 2010 06:45 PM
