Click Here
65 442 wheel size help
Old Jun 17, 2018 | 05:40 PM
65oldsrocket's Avatar
so I been pulling my hair out all day with wheel sizes and offsets on foe my 65 442. Currently I have old Anson 14x8s with a 3 1/4" backspace all the way around. I'm putting the Hurst dazzler wheels on it 15x8 with a 4" bs for rear and a 15x7 with a 3 3/4" bs for front . I'd like to run a 255/60/15 in rear and slightly smaller in front . Question is should I do the 8" wide all the way around or the 7" wide in front ? What will fit the best ? Thanks !
Old Jun 18, 2018 | 08:00 AM
You want zero OFFSET. Backspace is a poor metric to use because it depends on wheel width, material, and shape of the lip. Offset is independent of wheel width. For a 7" wide wheel, zero offset will yield a backspace between 3.75" and 4", depending on the thickness of the wheel lip. For an 8" wide wheel, backspace for zero offset will be between 4.25" and 4.5".
Old Jun 18, 2018 | 11:02 AM
ok, I actually changed it to 15 x 8x all around with a 4" bs . I guess I can always run a 1/4" spacer if necessary
Old Jun 18, 2018 | 11:22 AM
Better recheck your math. You would need a NEGATIVE spacer. Smaller B.S. means that the rim is pushed outboard already. A spacer would just make that worse.
Old Jun 18, 2018 | 11:46 AM
Didn't you say 4 1/4 or 4 1/2 bs ? In any case right now my wheels are 14x8 with a 3 1/4" bs and they are centered.
Old Jun 18, 2018 | 12:54 PM
If you have 4" B.S. and add a 1/4" spacer, you now have 3 3/4" B.S. and the wheel is closer to the outer fender lip.
Old Jun 18, 2018 | 02:29 PM
hurst68olds's Avatar
I'd stick with 15X7 with as close to "0" offset on the front
a 15x8 requires too many stars to align with tire size, ride height & 50 year old cars to avoid rubbing wheel lips and frame rails
Old Jun 20, 2018 | 04:03 AM
15x8s should be here this week , I'll let everyone know how they work out .. .
Old Jun 20, 2018 | 07:00 AM
oldsmobiledave's Avatar
65 wheel fit
15 x 8" will not work on the front of a 65 442. You will need a tall narrow tire on a 15x7" rim and 15x6" up front is better on a 65.
Old Jun 20, 2018 | 08:47 AM
i currently have 15x8s with like a 3 1/4" bs all the way around with 225/70/14s that fit really well
Old Jun 20, 2018 | 09:10 AM
droptopron's Avatar
delete
You have 15" rims w/ 14" tires?
Are you sure your current rims are 8" wide? How are you measuring that?
Old Jun 20, 2018 | 04:00 PM
typo
Clearly you have a typo here somewhere. I have tried many combinations on my 65 442 & 8" up front & wide tires up front are not user friendly.
Old Jun 23, 2018 | 07:13 PM
So far the rear 15x8 4" bs with a 255/60/15 drag radial seems like it's going to fit. Have about 2"s on the inside and very very close to the wheel well inner lip . But the car does seem like its sitting to low in the back and is way to soft in the rear .
Old Jun 24, 2018 | 06:31 AM
rear wheel & tire on 65 442
275 60 15s ON 15X8.5" RIMS WITH 5" BS.
The differential is a 1966 Chevelle 12 bolt which is 1" wider than the original 8.2" 10 bolt that I took out of the car.
Old Jun 24, 2018 | 07:06 AM
​​​​​​​sorry they are actually 14x7s
Old Jun 24, 2018 | 07:07 AM
wow that looks great , what springs and shocks are you running in the back ? And what wheels tires are you running up front ?
Old Jun 24, 2018 | 07:54 AM
Fyi
I have had many different wheel & tire combos. On the front the best fit is a 15 x 6" rim with a tall narrow tire like a 215 75 15.
rear springs were new replacement from strange and the shocks are KYB all around.
Best looking rim on a 65 442 is by far Torque Thrust Ds and redlines would be a home run.
Old Jun 24, 2018 | 08:40 AM
that looks great ! I was originally going with the torque thrust d then decided on the hurst dazzler 15x8 4" bs rear. I was also going to try and do the same wheel in the front but now might do the 15x7 with 3 3/4" bs
Old Jun 24, 2018 | 09:23 AM
go 15 x 6" up front with a tall narrow tire.
Old Jun 24, 2018 | 06:15 PM
Just ordered the 15x7s with a 3 3/4 bs for front
Old Jun 25, 2018 | 12:03 PM
So for the front I'm stuck with a 15x7 3 3/4" bs. Do you think I can fit a 235/60/15 on the front ? 225/70/15 ?
Old Jun 25, 2018 | 01:58 PM
front tire
so for the front i'm stuck with a 15x7 3 3/4" bs. Do you think i can fit a 235/60/15 on the front ? 225/70/15 ?
215 65 15
Old Jun 25, 2018 | 03:11 PM
215 65 15
is love to get a wider tire in the front. Don't think it will fit ?
Old Jun 29, 2018 | 05:05 PM
Well wheels are on and I'm really happy to report that they fit perfectly. 15x7, 3 3/4" bs with a 235/60/15 front. No rubbing and just clears lock to lock. Rear is 15x8 4" bs with 255/60/15 tires. Fits perfectly a couple inches on the inside and 1/4" between the tire and inner fender lip on the passenger side and a 1/2" in the driver. Going to put air bags in tomorrow to get another inch in height then will post some pictures.
Old Jun 29, 2018 | 05:16 PM
therobski's Avatar
Are you running stock height front springs and an A-body stock front suspension? I would like to see the stance when you send the pictures, thank you!!
Old Jun 29, 2018 | 05:34 PM
yes, stock 65 442 suspension all the way around but everything is brand new so nothing is lower or sagging .
Old Jul 1, 2018 | 12:48 PM
Old Jul 1, 2018 | 12:49 PM
Not the best pictures but you can get an idea of the stance. This is with the air bags at 30 lbs in the rear . Gives it a little rake to the front .
My2nd 69 442
May 27, 2018 03:05 AM
midnightleadfoot
May 15, 2017 07:57 AM
mikeybee455
Mar 28, 2015 07:16 PM
72cuttys
Wheels and Tires
Sep 29, 2013 09:50 AM
speedaddict78
Wheels and Tires
Jan 13, 2013 04:56 PM
