Click Here
1969 Cutlass s convertible 15inch rally rims ?
Old Apr 3, 2019 | 10:56 AM
69oldscutlass's Avatar
What is the best stock 15 inch Ralley rims . Did they make a 15 inch rims with screw in center caps.
Looking for rim code and lrgest tire size with out rubbing.
Old Apr 3, 2019 | 01:08 PM
I moved your post as the one you posted on is an info only type thread.
Old Apr 3, 2019 | 05:23 PM
4speed455's Avatar
They did make a 15 bolt on cap version. They are hard to find because they were only available for one or two years and are are priced accordingly. I run 245 60 15 BFG Radial TA’s on all for corners with no rubing on my 70 convertible. I think I could go wider in the rear but not the front.
Old Apr 3, 2019 | 05:35 PM
My car is the same with 245-60-15s all around. Some folks have run 255-60-15s up front without rubbing, but on mine the drivers side rubbed on the fenderwell lip during turns. Prolly depends upon the suspension setup and condition as to whether it will rub or not. For the rears, 295-50-15s fit with room to spare but the 69s have less space in the rear wheel wells, so I don't know what the max width is for your car.
This is a picture of 14" bolt-on center wheels and 15" snap-in center wheels. Kinda hard to tell the difference unless you know what you're looking at.
Old Apr 3, 2019 | 05:39 PM
Here's the code stampings on one of my 15x7 wheels.
RocketRonnie
Wheels and Tires
Feb 25, 2019 02:10 PM
atkinsom
Wheels and Tires
Jan 22, 2018 06:15 AM
cutlass xombie
Wheels and Tires
22
Jan 19, 2012 06:06 PM
tim72
Apr 21, 2010 06:45 PM
Oldsproject
Dec 8, 2008 06:43 PM
