1950 tudor attaching door hinge sealing strip
From: San Francisco area in formerly wonderful California
This is fabric piece that goes between the door and the cowl. Is it glued or what? Any help is appreciated.
Thanks---Bill
Thanks---Bill
sealing strip
Fusic calls it a "Body Hinge Pillar to door sealing strip" and one side attaches to the cowl below the windshield post (A pillar???) behind the hinges. The other side attaches somewhere and I assumed by the name, the door. The die cut edge matches the shape of the door or the fender.
My question then is where exactly does it go and how is it attached? Glue or what?
The ones that came off my car were in terrible shape and all I have is part of the piece and the metal hook at the bottom that is screwed to the A pillar
Thanks foor any help---Bill
I have purchased the door seals you are talking about for my '50 Olds.. The piece is a large rubber affair that attaches to the cowl in front of the hinges. It is then loosely attached to the front fender.. without this seal there would be a large gap between the fender/cowl and subsequently a large gapping path to the door.
The seal does not actually attach to the door, the constant flexing caused by the opening of the door would cause the seal to fail very quickly..
It could be that the original seal had a fiber, cloth like core, I'm not sure if the re-pops have this feature..
If you have read through my postings to my '49 olds 88 club sdn topic, you will note that the front ends on the '49-50 Olds is very difficult to properly install..
The doors have to be fitted to the cowl/body, then the hood has to be fitted to the cowl/fenders. After the doors and hood have been properly installed, the front fenders and related sheet metal can be installed.
I separated the inner fender splash pans from the fenders prior to having them stripped/dipped. In lieu of re-spot welding them like original, I bolted them to the fenders with 1/4" shoulder headed bolts and nuts.. This gives the illusion of being more consistent with new cars and allowed for the panels to be powder coated in a satin black. Bill
Wow! Good idea on the inner panels.
Re the seal, does it firmly attach to the fender via the two bolt holes in the A pillar or is it just loose in there? It looks like the straight edge is mounted on the A pillar with cut edge facing front then folded back over itself. Also, at the top there are three "flaps", the center one with a hole that doesn't line up with anything....
Thanks for your help
Bill
Bill
ddd777
Body work
18
May 11, 2013 07:45 AM
