Carb rebuild, fuel pump?
I am going to be swapping a 1963 394 into my 56 olds, i am going to use the carb from the original 324 on the 394 so the linkage is correct. The carb needs a complete rebuild as there are mud dauber nests in it. What is a reputable shop i can send my carb to for rebuild and rejetting? Also can i use the fuel pump from the 324 on the 394 to keep the fuel lines? Thank you
