Generators again
Old Oct 24, 2019 | 08:11 PM
DFitz's Avatar
74 2.8L Capri
Generators again
Tedd, Red,
I couldn't find the old thread about generators from last year. Unfortunately, Tedd, you were right. My rebuilt generator on the '55 crapped out in less than 3k miles. I got it from Fusick, out of warranty of course, and wrote them a letter, but doubt it will do any good.
Everyone, caution, rebuild your own generators. Don't opt for a rebuilt from Fusick. I don't know where Fusick is getting their rebuilds, but the brushes completely disintegrated after less than 3k miles. Nothing left. Crumbled parts fell out of the back of the generator when I took it out. Put another rebuild in, hopefully it will last longer than 3k miles.
For the moment I can go back to driving at night, and not driving on the battery! I might even turn the radio on....
Old Oct 25, 2019 | 05:16 AM
That's a bummer that you had bad luck with the Fusick generator. What rebuild kit did you get to replace the brushes in your generator? I would think the only sources for a kit like that would be Fusick or Kanter.
Old Oct 25, 2019 | 08:01 PM
DFitz's Avatar
74 2.8L Capri
I got the whole generator rebuild from Fusick. Mine was original w 130k on it. Everything worn out. So I figured get a nice one. We'll see on the second try.
Dave
Old Oct 27, 2019 | 05:00 AM
stellar's Avatar
stellar
If the battery, regulator and wiring is in good order, the genny should last a lot longer than 3K, but 130K is over the top. I suspect the original has been rebuilt or repaired at least once in the past. How much does the Fusic gen cost? Do they require a core? If the brushes were crumbled and in pieces the armature is probably bad and new brushes won't solve the problem.
Old Oct 27, 2019 | 11:00 AM
twintracks's Avatar
The Chinese brushes are junk! I've had the same experience.
I use the Burton Co in Michigan for rebuilds. Try to find NOS Delco brushes wherever you can.
Old Oct 27, 2019 | 12:54 PM
stellar's Avatar
stellar
Good brushes cost almost 4 times as much as the cheap ones, but it is worth it. The brushes I use are USA made. They are made by a company that specializes in brushes and makes them for just about everything. They are also a supplier for many OE applications.
Old Oct 27, 2019 | 04:29 PM
Daiv8or's Avatar
Maybe it's time for a Gener-Nator conversion. Your stock generator with alternator guts in it that is more powerful with more amp capacity, produces power at all RPMs and presumably more reliable. Totally stock under the hood, but works way better. They seem like a great option. I don't know what it costs though.
https://gener-nator.com
Old Oct 28, 2019 | 03:48 AM
DFitz's Avatar
74 2.8L Capri
Newish battery, new regulator with the last generator. Wiring is all good.
No, the generator I replaced 3 years ago was totally original and stock. The car has been in the family since new. Agreed with the analysis with the crumbled brushes, I don't trust the current generator even if I were to replace them. The holders were bent, and the remains were bouncing around inside the generator.
I just adjusted the brakes, and went for a test drive. At least the generator worked for about 3 miles!
Old Oct 28, 2019 | 03:51 AM
DFitz's Avatar
74 2.8L Capri
And yes, I know the radiator recovery tank is not stock, but I was tired of having to top off the radiator all the time. The engine runs nice and cool, just shy of half on the gage, can't seem to get it any hotter no matter the weather!
Thanks for all the suggestions.
Old Oct 28, 2019 | 04:45 AM
Oh yeah!
I hope you have better luck with your new generator.
Old Oct 28, 2019 | 02:42 PM
Tedd Thompson's Avatar
I think my last 3 generators (all Wilson rebuilds) all went bad in less than 3 thousand miles, one was DOA and I'm not counting that one .I now get them rebuilt by a old world starter generator shop. No issues so far and I'm a happy camper.
It's the we will replace them no questions asked at no charge that gets you hooked. also makes you stay close to home because you have no trust in your car anymore.Throw in a regulator that goes bad and I was a little gun shy...... Tedd
Old Oct 28, 2019 | 08:15 PM
OLDSter Ralph's Avatar
What went bad most ? Brushes ? Bushings ? Or ?
Old Oct 29, 2019 | 07:17 PM
The first one was the original or at least very old . The bearing went out and shorted to the case screwed up the case. Probably my fault for putting too much of a tight on the belt. I set it up like a alternator not smart. The next one would not generate a volt and It went back the same day The rest I just pulled them off when they quit and sent them back.I did use the last one as a core as I didn't have anything good to rebuild in my stash and It was rebuildable...... Tedd
rodan
Jun 16, 2017 08:17 AM
farmer52
Nov 14, 2016 03:40 PM
Bfg
Jun 12, 2016 04:53 PM
Snolab
Oct 26, 2014 11:31 AM
allyolds68
Mar 22, 2013 11:57 AM
