'56 rear motor mount orientation?
Old Nov 11, 2019 | 02:53 PM
michaelkellett's Avatar
Can someone show me a photo or drawing of the correct orientation of the rear motor mounts on a '56 Olds with the 324 Rocket motor and Jetaway/Hydramatic transmission? I have the new mounts, the crossmember is in place, and I can't for the life of me figure out where all of the holes are supposed to line up. I'm replacing the Jetaway with a modified 700R4 from Ross Racing Engines, which is supposed to use the stock crossmember (with a notch cut out for the pan) and stock mounts, but I'm stumped here. Thanks!
Old Nov 11, 2019 | 07:05 PM
Charlie Jones's Avatar
Phantom Phixer
None of these transmission swaps are a " bolt in " proposition .
Yes , you do need the stock mounts and crossmember . But , you will need the services of a good welder / fabricator to fit them to this transmission .
Old Nov 12, 2019 | 07:35 AM
Not true. The Ross Racing modified R4 uses the stock mounts with a notched crossmember, but no welding required. What I'm looking for is confirmation of which of the rear motor mounts goes on which side, since they are not marked and are mirror images of one another.
Old Nov 12, 2019 | 08:10 AM
59-59-59's Avatar
I used the Ross TH-400 conversion to a 394, and had to notch out the crossmember and also had to move it, I think like an inch or two back from the original mounting position. Obviously new holes had to be drilled. I also thought it was a bolt in and go deal, with no modifications to the crossmember. Your results may vary since this was done in a 57. If you still want a picture let me know
Old Nov 12, 2019 | 08:19 AM
If you can tell me which way the rear motor mounts orient that would help do the rubber blocks face the front or the rear of the car?
Old Nov 12, 2019 | 12:33 PM
59-59-59's Avatar
Pic stolen from someone here that did the swap
Old Nov 12, 2019 | 12:56 PM
So here's my question... Where I have the motor mount located now, only the bottom hole in the mount aligns with a threaded hole in the block/bell housing. The top hole lines up with a non-threaded hole in the bell housing on the trans, but there's no hole in the block, threaded or otherwise. Either I'm lining up the mount on the wrong holes, or the stock transmission had a fastener coming from the inside, or???
Old Nov 12, 2019 | 02:35 PM
59-59-59's Avatar
Do you have the lower flywheel plate bolted to the engine yet?
Old Nov 12, 2019 | 02:41 PM
Yes.
Old Nov 12, 2019 | 04:25 PM
Phantom Phixer
Looks like the easiest thing to do here is to drill and tap the block , using the hole in the bellhousing on the trans as a guide .
Drill and tap to the same size as the other bolt . Then screw a bolt in it .
Old Nov 13, 2019 | 07:01 AM
Andreas.Johansson's Avatar
When I did replace my mounts on a all stock 1953 Olds w Hydramatic, the line up on the holes did not match.
Ended up with enlarging the holes and weld the old ones.
My two cents...
/ Andreas
Old Nov 13, 2019 | 07:06 PM
Tedd Thompson's Avatar
If mine I would call Tony at Ross and ask him, he is the one that builds them..... Tedd
Old Nov 13, 2019 | 07:16 PM
I have... He's out of town/communication and my build is dead in the water till I figure this out, so...
Old Nov 19, 2019 | 02:21 PM
So an update to this story... Turns out there are 1" spacers that go between the motor mounts and the new bell housing, which I did not receive with the transmission, and the top holes that line up with the rear mounts were drilled, but not threaded in machining. So, after tapping the holes and adding the requisite spacers, I should be able to mount the engine/transmission with no modifications to the stock mounts or crossmember.
Old Nov 19, 2019 | 07:53 PM
mpolds's Avatar
1954 - 1956 Rear Motor Mounts
For anyone who is struggling with (perhaps) the wrong mounts --
1954 - 1956 Rear Motor Mounts are different for Manual vs Automatic Transmission....
At this moment in time, I have both of them N.O.S. U.S.A. made....
(The "angle and the dangle" is slightly different...)
Always best to simply call me -- Craig -- 516 - 485 - 1935... West Hempstead, New York.
1971raresx
Aug 18, 2016 08:22 AM
74 fastback
Oct 5, 2015 05:29 PM
madmax442
Apr 14, 2015 05:46 PM
rmoths
Dec 5, 2012 06:50 PM
Beob
Apr 5, 2011 10:14 AM
